Attached Link: Whatever 3d
Your text is coming up as sort of cyan on white...but if you're looking for Bajoran, I seem to remember someone has a morph for this.If you can model, Dr. Geep has a tutorial on how to make a morph in Wings 3d. I did one...once, and it was a brute-force morph. I just moved every other edge on the nose forward slightly, and created the morph (only one I've ever done...;) Poser smoothed the rest, once it was dialed in.
Aside from that, try here...
You could also create a displacement map to achieve the same effect..
Iy you are using M and V3 you can use the Predatron morphs over at Daz to produce a host of Trek characters. Vulcan, Romulan, Ferengi, Klingon etc With the M3 pack use alien nose A to make the Bajoran nose rinkles
http://www.daz3d.com/i/3d-models/-/m3-character-morph?item=3622&_m=d
http://www.daz3d.com/i/3d-models/0/victoria-3-character?item=3431&cat=&_m=d
Guys, I'm looking morph characters star trek, particularly Bajorans.
Can anyone direct me?
Or explain how to morph the nose?
thanks Jaelle
