Thu, Nov 7, 12:44 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 07 11:22 am)
Subject: who can help
daved ( ) posted Wed, 24 March 2010 at 11:02 AM · edited Fri, 18 October 2024 at 3:17 PM
hello all poser pro 2010 working pretty well except every time i want to enter the material room poser pro2010 crashes. any thoughts?
MysticDaniel ( ) posted Wed, 24 March 2010 at 11:20 AM
 Maybe you need more Ram? Make sure you have no other programs open as this will eat up your Ram.
IsaoShi ( ) posted Wed, 24 March 2010 at 11:26 AM
First suggestion (assuming you are using OpenGL display) would be to switch to SreeD display in the Pose room, then see if you can switch to the Material room. If you can, this problem is most likely caused by an issue with your graphics card driver, so tell us what graphics card you have and someone should be able to advise you.
Also, have you reported this to SM?
dphoadley ( ) posted Wed, 24 March 2010 at 11:42 AM
"hello all poser pro 2010 working pretty well except every time i want to enter the material room poser pro2010 crashes. any thoughts?"
Have you tried prayer and incantations?
dph
daved ( ) posted Wed, 24 March 2010 at 12:13 PM
thanks switching between opengl and sreed and then back to opengl seems to correct any problems
ratscloset ( ) posted Wed, 24 March 2010 at 11:25 PM
You might want to double check to see if you do have the latest Driver. That normally indicates a Driver issue, if switching to SreeD helps.
ratscloset
aka John
