Bryce F.A.Q (Last Updated: 2024 Jun 26 1:13 pm)
If I remember from another post a couple of months ago Bryce is not supported by either a network or by duel processers. You must dedicate one process for Bryce. (some people dedicate one processer for Bryce and one for Poser so they can render at the same time.) Boni
Boni
Bryce does not support duel Cpu's I did a test a while back to prove this. I did a render of 2 big glass balls at 10" X 8" X 300 dpi on 2 systems A. PII 300 with 128 meg Win 98. B. Duel PII 450 with 128 MEG Win NT. The Diff in rendering time was 33% faster. This proved that Bryce only used 1 CPU. The render speed increase was the same as the CPU clock speed increase. Spike
You can't call it work if you love
it... Zen
Tambour
One more thing to keep in mind: Rendering programs like RAM. the more you have the better. Keep this in mind when you multi-task. or better yet, Don't multi-task. keep your system cleen and your sys tray empty. Spike
it... Zen
Tambour
Hello there. I installed Bryce on a dual processor machine, and then tried to access it through a shared drive.. Umm..aside from actually running bryce on that machine..is there a way to ..sort of render using that machine's processorS? It seems that although I am runnning the program off the shared drive, it is still happily using my local processor etc. :) I was just..dreaming hee hee..that perhaps there was some way to utilise that dual processing power :)
