If you actually examine the mesh, you will find that indeed there are two distinct layers of eye lashes. Try testing with an all grey lash map and it'll be easier to see.
It would seem to me to more realistic to have layers than all the lashes in one unnatural line. That said, if you prefer them in one line, then perhaps creating your own lash map with no lashes on the "strips" sections might improve results.
I think what you see on the image is not that the lashes are detached but you see a bit skin from the bottom eyelid through the gaps in the top lashes.
A little eyeliner will fix that.
When I close V4's eyes, I don't see what you see.
Here I've colored the upper lash black and the lower lash white.
The eye is partially closed, using the morph EyesOpen-Close = -.2.
It's pretty easy to see that the upper lash is exactly where it should be.
Looks like they set the morph limit incorrectly.
Here' my same-size render of the eyelashes with the morph at -.49.
