Mon, Dec 2, 2:12 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Nov 28 3:44 pm)
Carrara Free Stuff here.
Subject: update model created in Carrara 4 Pro to Carrara 7 Pro
DFWasserboehr ( ) posted Sat, 10 April 2010 at 11:59 AM · edited Fri, 29 November 2024 at 10:50 PM
I created a model of the Hindenburg a while ago in Carrara 4. I'd like to use it in Carrara 7 but have encountered conversion problems. Some of the geometry shows up other parts do not. I'd like to work with the model because I spent a lot of time on it. Is there a way to make this conversion so that the model comes in cleanly. I still have Carrara 4 on my machine. Thanks!
Plutom ( ) posted Sat, 10 April 2010 at 12:26 PM
Can you convert it to an .obj in Carrara 4, import that into Carrara 7, then select an object in the .obj, go into the vertex room and convert the "blank" page to vextex modeling?  I've found that you can convert various .objs back into vextex modeling, one object at a time.  Jan
DFWasserboehr ( ) posted Sat, 10 April 2010 at 12:34 PM
 will give it a try. Thanks!
ShawnDriscoll ( ) posted Sun, 11 April 2010 at 12:06 AM
That's weird.  It should just open as a CAR file.  Unless you are missing plugins.
DFWasserboehr ( ) posted Sun, 11 April 2010 at 11:56 AM
 I did save it as an OBJ and it translated poorly. The Carrara 4 body of the Hindenburg was a spline object and I converted it to a vertex object. It still does not show up in 7 but all the other pieces do. Its really weird.
Plutom ( ) posted Sun, 11 April 2010 at 2:37 PM
Wow!  I made a model in Raydream 3D saved it as an .obj and it came up just fine in Carrara 5 Pro.  Even converted several splines to vertex using Carrara 5 Pro vextex modeling room.  Can you save the .obj as a .car in Carrara 4 and bring the .car aboard Carrara 7?  It is very possible that the .obj is defective.  Jan
