Sat, Feb 1, 4:29 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Subject: Help with editing a CR2
tonymouse ( ) posted Sat, 10 April 2010 at 4:36 PM · edited Wed, 29 January 2025 at 10:20 PM
I have the WantedDOA set from DAZ and on the left forarm it has twist, sided to side, and bend showing in the body part, in the  rigth forearme it has only twist and side to side, I am looking but not seeing what line of code I need to change to allow me to see and use the bend in the right forearm. Anybody who knows more about the Cr2 than me( that would be just about anybody ) Help.
Thanks in advance.
gibby.g ( ) posted Sat, 10 April 2010 at 5:42 PM
I have this one. Mine is for M4 (in case there are others) and I've just loaded up the jacket and I don't have the problem. Have you tried to reinstall it?
chriscox ( ) posted Sat, 10 April 2010 at 7:46 PM
Quote - I have this one. Mine is for M4 (in case there are others) and I've just loaded up the jacket and I don't have the problem. Have you tried to reinstall it?
He of course meant the shirt.
Under  "rotateY yrot" for the rForeArm look for hidden and change the value from 1 to 0
Chris Cox
chriscox ( ) posted Sat, 10 April 2010 at 7:51 PM
Also you could use and unhide dial script like the one by Dimension3D
Chris Cox
gibby.g ( ) posted Sun, 11 April 2010 at 4:35 AM
Quote - > Quote - I have this one. Mine is for M4 (in case there are others) and I've just loaded up the jacket and I don't have the problem. Have you tried to reinstall it?
I meant the coat but having checked the shirt as well mine does have the same missing dial.
tonymouse ( ) posted Sun, 11 April 2010 at 9:25 AM
Thank you that seems to have done the trick.
