Mon, Jan 13, 6:55 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 11 8:46 pm)
Carrara Free Stuff here.
Subject: saveing out an SWF
col ( ) posted Fri, 27 July 2001 at 8:46 AM · edited Sun, 17 November 2024 at 9:53 PM
Does anyone know if there s a way of exporting an SWF flash file from Carrara. At the moment I have to save as a 3DS and load the object onto a PC and use Swift to convert it into a SWF. Due to unfortunatly constraints I now have to use only a Mac, does anyone have a solution?
willf ( ) posted Sat, 28 July 2001 at 1:24 AM
I don't know much about Shockwave files (bitmap and/or vector) but GraphicsConverter will convert sequenced images (tiff, Pict, etc) to swf format. Located at: http://www.lemkesoft.com/us_gcabout.html Also some info about adding flash tracks and sprites to QT movie files at: http://www.apple.com/quicktime/products/tutorials/flashtracks.html
BobW ( ) posted Tue, 31 July 2001 at 5:15 AM
I have recently been experimenting with exporting from Carrara to Flash, with mixed results. I use the Toon Plug-in and the Poser Pro-Pack. With the Toon Plug-in I have rendered out to animated GIF and sequenced GIF. I import in to Fireworks to optimize the palette, then import to Flash as a symbol. The problem I run into the most with this technique is file size. With the Poser Pro-Pack, I import simple models from Carrara as wavefront objects and animate them in Poser, or I render an AVI movie from Carrara and import it into Poser as a background movie and render out to Flash. File sizes are fairly manageable, but no cool Carrara camera controls or other special FX. Also 12 fps seems to yield the best results for quality and file size in both applications.
