For the Upper Eyebrows, the Object color is set to the color of the hair you are using for Vicky 2, the Highlight and Ambient color are both black and the Reflective color is white. Transparency Min and Max are both set to 100%, Highlight and Transparency Falloff sliders at 0, and the only map is the transparency map, loaded in the transparency section of the material editor. :) Laurie
Thanks sooo much Laurie for this detailed explanations. This looks very great ! Now I will run to Renderosity's free stuff (cannot find yet a "TRANS" folder in the Poser stuff, but hope I will...) I have bought Vicki and Victoria without a texture, but Vicki 1 was supposed to come with her texture anyway. I only cannot find it in my Poser and wrote to Daz3D in hoping to get an answer. Thanks again, I'll try every thing you suggested and will let you know then. I have not much time right now, but give me a few days. :-)Guitta
I don't think Vicky 1 came with a texture either Guitta. The good news is that there are tons of free ones...and very nice ones too :). Since Vicky 2 uses the same maps as Vicky 1, you shouldn't have any trouble finding a nice map for either of your Vickys. And with that eyebrow trans (if there isn't a lash trans with it, there are free lash trans maps too) you should be all set! :) Laurie
![file_196685.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_196685.jpg)
Hi Guitta, Following are some screenshots of the settings for Vicky 2's Upper Eyebrow trans. Keep in mind that any dial settings for that area of the face are at 0.00. The only thing I changed is the material settings. The first is the setting for the Upper Eyebrows (the only part that you actually need to worry about). There is NO TEXTURE on the upper eyebrows, only the trans map. Just make the color of the eyebrows close to the color of the hair that you are using on Vicky 2. If you don't have an eyebrow trans for Vicky 2, there is one for free in the Poser Freestuff here by TJ...just search for Trans and it should show up on the 1st page. This trans is specifically for Vicky 2.
