Sun, Jan 12, 2:07 PM CST
Subject: Imported object renders black
Animoottori ( ) posted Tue, 04 May 2010 at 7:20 AM · edited Sun, 12 January 2025 at 2:34 AM
Hi,
I've got this weird problem with Poser 6. I've imported an object from Lightwave and saved it as a prop.
When I import the prop into an empty scene and try to render it, it renders black. If I import any other object into the scene, the object renders normally. If I set the object not to cast shadows it also renders normally but I'd rather not do that.
It seems like there are invisible shadow-casting quad-faces around the object that cast their shadows only when object is alone.
The problem is quite easily fixed afterwards but if some one knows how to avoid it from the start I'd be glad to hear it.
Thank you,
-Animoottori
BAR-CODE ( ) posted Tue, 04 May 2010 at 7:33 AM · edited Tue, 04 May 2010 at 7:35 AM
Props need to have a FIGURE in the scene to render normaly..
Just try to put a Shoe or any figure in the scene and re render...
EDIT with small props that is ... big props usualy render normaly..
Chris
IF YOU WANT TO CONTACT BAR-CODE SENT A  PM to 26FAHRENHEIT  "same person"
Chris
My Free Stuff
Animoottori ( ) posted Tue, 04 May 2010 at 8:52 AM
Ok. The props I've created are actually quite small. Now I can be at ease because I know why it is happening.
Thank you Chris.
-Animoottori
BAR-CODE ( ) posted Tue, 04 May 2010 at 9:36 AM
Your Welcome :-}
Chris
My Free Stuff
TrekkieGrrrl ( ) posted Tue, 04 May 2010 at 10:58 AM
Quote - Props need to have a FIGURE in the scene to render normaly..
Chris
Uhm that's new to me. And I've made, and rendered, lots and lots of small props. We're talking stuff like a single thumb tack ect. And it has never rendered black or in other ways odd.
I'd guess that you've either got souble sided polygons in your mesh, in which case it may render black, or perhaps inverted normals (but in that case the preview should look odd, too)
So my guess is double sided polygons self-shadowing.
It is someting you've modeled yourself? if yes, then In which program and how? :)
nruddock ( ) posted Tue, 04 May 2010 at 11:54 AM
I think they fixed the "single small prop renders black" problem with P7 (or it may have been one of the later P6 SRs).
A workaround for older versions was to scale up the prop significantly (I forget what factor was sufficient x10, x100, or x1000).
bagginsbill ( ) posted Tue, 04 May 2010 at 11:57 AM
This is a known bug in recent versions of Poser.
TG - To see the problem you have to meet a a couple criteria. Change anything and it goes
away.
1) Depth -mapped shadows. Doesn't happen with RT shadows.
2) Only one tiny object casting shadows. If there is another tiny object some distance away, or anything not tiny, it doesn't happen.
3) Must be one of the newer versions of Poser that has the bug. I think P6 doesn't have it.
Contrary to what bar-code said, it has nothing to do with figures.
bagginsbill ( ) posted Tue, 04 May 2010 at 11:59 AM · edited Tue, 04 May 2010 at 11:59 AM
With another copy of the prop about 15 inches away, it is fixed.
bagginsbill ( ) posted Tue, 04 May 2010 at 12:01 PM
Also fixed by anything not tiny, even if it is close. The "big" sphere is actually the standard Poser hi-res sphere - about 10 inches diameter.
bagginsbill ( ) posted Tue, 04 May 2010 at 12:02 PM
But if the normal sized object doesn't cast a shadow, the problem is there.
bagginsbill ( ) posted Tue, 04 May 2010 at 12:03 PM
With ray-traced shadows, there is never a problem.
RT shadows are superior to DM shadows in practically every way. More realism. More control. More accuracy.
I never use DM shadows anymore. Not even for hair. It just looks fake, so forget it.
bagginsbill ( ) posted Tue, 04 May 2010 at 12:08 PM
Two tiny props 9 inches apart. Broken.
10 inches apart. Fixed.
TrekkieGrrrl ( ) posted Tue, 04 May 2010 at 1:50 PM
Aha! When Poser 5 came out with raytraced shadows, I pretty much switched to those and never looked back L That'll explain why I haven't seen this problem in the wild.
Or at least sorta... but I guess it wasn't present in Poser 4? Because I really can't recall seeing it and some of my old props are still pretty small.
Also I won't call what you showed here "rendering black" at all. I'd call it "being oddly shadowed" or something but it isn't black. I've seen degenerate facets (at least that's what UVMapper calls them) render completely black and I'm suspecting it's something like this the OP is seeing.
I may of course very well be wrong :)
bagginsbill ( ) posted Tue, 04 May 2010 at 2:16 PM
Ah, but I render with GC. My "dark" is another man's "black".
bagginsbill ( ) posted Tue, 04 May 2010 at 2:18 PM
Here's a render I was using in another thread today to demonstrate how luminance should (and does) fall off with distance.
This is rendered with GC. The most distant (100 feet away) prop is dark, but clearly not black.
Compare without GC. Most people would say the distant prop rendered black.
markschum ( ) posted Tue, 04 May 2010 at 2:19 PM
Having a figure in the scene fixes the bug by having another large object in the scene.  I used to get this when testing earrings and piercing studs.
Animoottori ( ) posted Wed, 05 May 2010 at 6:26 AM
This was really the case. Changing lights to cast RT shadows fixed the problem as did adding another object. The object isn't actually as small as earrings but still it created the problem.
I created the object with Lightwave and I'm using Poser 6. Both on Mac OS X.
Thank you all for the information.
Kind regards
  -Animoottori
TrekkieGrrrl ( ) posted Wed, 05 May 2010 at 7:35 AM
 BB I'd say your distant prop on the non-GC'ed image was ... gone L
But it's an interesting bug, this. One I've never met in the wild myself so I'm intrigued! And now I know how to avoid it, should I ever encounter it!
