Fri, Nov 22, 7:15 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: wxpython - add label to wx.BitmapButton?
Netherworks ( ) posted Sat, 08 May 2010 at 6:58 PM · edited Fri, 22 November 2024 at 7:11 AM
Heyas,
I am trying to work with Poser 8/Pro 2010 wxpython.  I created a blank button .bmp that I'm using as a template for buttons in a panel.  I am wondering if there is a way to add text to the blank buttons without having to use a different graphic for each button.
I am using wx.BitmapButton to utilize the buttons but can't seem to figure out a simple way, other than making a dozen different graphics, to add text to them.
I haven't been able to find a lot of information or examples of this.  The wxpython documentation online reads worse than stereo instructions.
semidieu ( ) posted Tue, 11 May 2010 at 4:40 AM
I dont think it's possible (at least not easily - you will perhaps need to 'completely' rework the class).
Depending on what you do, why not using a simple button with different background colors ?
Netherworks ( ) posted Tue, 11 May 2010 at 1:18 PM
Yeah, I went with wx.lib.buttons.GenButton instead of Button (or BitmapButton) because you can customize it a bit more.  I'm a stickler for having things look halfway decent visually.   I first tried Button but it wants to use windows colors.  I set fore and background colors but there's still a border around the buttons and I prefer them in this case to be flat.
If I didn't need it to be a panel, I'd be using tkinter instead because in some ways tkinter is easier to deal with.  It's something that I wanted to be out all the time and dock.
What I made, if you're curious, is a "toolbar" (a panel with no caption) that can quickly switch camera views.
semidieu ( ) posted Tue, 11 May 2010 at 2:06 PM
Oh, that would be very nice :)
By the way, for the question you asked me by email, I didn't made something similar, so I don't know. From what I searched, it should behave the same way... But Mac never behave the same :)
Netherworks ( ) posted Tue, 11 May 2010 at 6:54 PM
Yeah, I haven't been able to figure out how to make the buttons on the bar reorder.  There's 12 buttons and they are horizontal on one row.  I can't make them go 3x4 and so on by changing the pane size but would be cool if I could get it to work.
I could put it out there as a freebie and leave the code exposed if you are anyone wants to fiddle with it.  However, you might shriek in terror when you see my coding style :D
I've attached an image.  It does remember it's layout and if it's docked or not (using pickle).  You can right click in an empty space to get the floating/docked menu.  I tried to make it visually fit in with the UI.
semidieu ( ) posted Wed, 12 May 2010 at 7:34 AM
That's really nice !
Why don't get the panel width and, depending of the size, make it two-three rows ?
Another way would be... to use a wx.listctrl, using icons ? (Dbl)-Click an item would select the camera and it does reorder automatically...
