Sun, Jan 12, 7:17 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: This probably means that Tcl wasn't installed properly.
Stan57 ( ) posted Fri, 14 May 2010 at 11:52 AM · edited Thu, 09 January 2025 at 4:06 PM
Need some help here please.
Im using PoserPro v7.0.4.220  i am getting this error
Traceback (most recent call last):
  File "C:Program Files (x86)Smith MicroPoser ProRuntimePythonposerScriptsScriptsMenuRealism KitsOcclusionMaster.py", line 20, in ?
    tk = Tk()
  File "C:Program Files (x86)Smith MicroPoser ProRuntimePythonliblib-tkTkinter.py", line 1569, in init
    self.tk = _tkinter.create(screenName, baseName, className, interactive, wantobjects, useTk, sync, use)
_tkinter.TclError: Can't find a usable init.tcl in the following directories:
    {C:/Program Files (x86)/Smith Micro/lib/tcl8.4} {C:/Program Files (x86)/Smith Micro/lib/tcl8.4} {C:/Program Files (x86)/lib/tcl8.4} {C:/Program Files (x86)/Smith Micro/library} {C:/Program Files (x86)/library} {C:/Program Files (x86)/tcl8.4.7/library} C:/tcl8.4.7/library
I read somewher this might be caused by a newer version python,which i do have its used with Vue 8. My system is windows 7 64 bit,poser runs fine,everything runs fine except for this error
Thanks in advance
Stan
Jack Of All Trades Master Of None
semidieu ( ) posted Fri, 14 May 2010 at 2:02 PM
I remember have seens this.... Did you tried reinstalling poser (without uninstalling it): this way, Poser Python will be again correctly installed.
Stan57 ( ) posted Fri, 14 May 2010 at 4:42 PM
I tried installing the updates, i guess this really leaves me no choise.
nruddock ( ) posted Sat, 15 May 2010 at 3:29 AM
An important thing to figure out is what you did that caused the problem so that you know what not to do again.
One known cause is installing the standalone version of WW in the Poser directory.
semidieu ( ) posted Sat, 15 May 2010 at 8:34 AM
That's it! I saw this problem when installating Warddrobe Wizard in the Poser directory!
