Tue, Dec 24, 10:40 AM CST
Subject: Import problem: Poser dynamic cloth into Vue
lookoo ( ) posted Sun, 16 May 2010 at 5:06 AM · edited Tue, 10 December 2024 at 3:41 AM
Content Advisory! This message contains nudity, violence
Hi folks!
This is at least the second time I have nearly insurmountable problems getting my Poser 6 charater into Vue 7.4 infinite.
This is what my current test renders look like in Poser 6:
http://i4.photobucket.com/albums/y113/lookoo/Render1.jpg
http://i4.photobucket.com/albums/y113/lookoo/Render3.jpg
And this is what a test import into Vue 7.4 infinite looks like...
http://i4.photobucket.com/albums/y113/lookoo/Fubarimport.jpg
Obviously, I have used dynamic cloth in Poser 6, and I suppose the problems are related to this. What is invisible in Vue is not just the dynamic cloth but the Figure the dynamic cloth is attached to, plus a few props attached to this figure, although some of thoser emain visible, strangely... I should add that in my very first import attempt the woman was visible but the dynmic cloth was imported incorrectly.
I have recalculated the dynamic cloth several times in Poser, I have resaved the scene under several scene names and I have created a new one with the guy into which I imported the scene with the woman warrior. In Vue, I have unchecked "use quaternion interpolation" in the import menu. All this hasn't brought the invisiblewoman back yet ;)
I have had the very same problem with my last image where I used the same character with dynamic cloth as well. There, I got so frustrated that I made her invisible in Poser 6 and put a naked but morphed andt extured clone exactly into her position. This helped and suddenly the original woman became visible in Vue again, so that I could finally delete the clone again.
I would reallylike to understand what is going on here - and rectify it.
Any idea anyone...?
thefixer ( ) posted Sun, 16 May 2010 at 6:51 AM
Your poser files are compressed, you need to run the "uncompress script" inside Poser and then resave your pz3.
It will then come into Vue properly...
This is a known issue with Vue not liking obz etc. files..
Injustice will be avenged.
Cofiwch Dryweryn.
lookoo ( ) posted Sun, 16 May 2010 at 8:19 AM
Thanks for the tip! Hasn't quite worked for me until now, however. Do you have any suggestions on how to run this python script? I have let it run over my entire curious labs folder with my running P6 folder  and my P4 folder where most of my active runtimes are.  I have done this several times over now and then resaved my present Poser file, both under its name, then under a new name.
Neither import has worked though...
Rather frustrating, to be honest...
thefixer ( ) posted Sun, 16 May 2010 at 8:23 AM
No, sorry, if you've run the script on your runtimes and the problem persists, then it must be something else...
Uncompressing usually sorts this problem out, I don't have anything else to suggest, sorry..
Cofiwch Dryweryn.
tsquare ( ) posted Sun, 16 May 2010 at 8:06 PM
There should be a way of turning off compression, I would think, for the next scene you save.
