Fri, Nov 22, 7:47 PM CST
Vue F.A.Q (Last Updated: 2024 Nov 21 4:12 am)
Subject: i7 6 core cpu with vue 8 complete
ddaydreams ( ) posted Sun, 16 May 2010 at 10:33 AM · edited Sat, 02 November 2024 at 9:01 PM
Is anybody using a i7 6 core cpu on a 64 bit windows system running Vue 8 Complete?
Vue Complete has an 8 core limit on a 64 bit bit machine.
However I'm not sure if that limit means real cores or real and virtual.
I have Vue 8 Complete and was wondering if I get a 6 core i7 64 bit machine, Would would Vue 8 Complete report 12 cores?
On Infinite I would expect it to show as 12 cores because 6 are real and six are virtual cores.
Just as a quad shows 8 now. Infinite has unlimited core support.
Thanks
Frank
Frank Hawkins/Owner/DigitalDaydreams
Frank_Hawkins_Design
Frank Lee Hawkins Eastern Sierra Gallery Store
My U.S.A eBay Graphics Software Store~~ My International eBay Graphics Software Store
Abraham ( ) posted Mon, 17 May 2010 at 8:37 AM
I won't be able to really answer your question, I run vue 8.5 xStream but I can give you some info about the performances
Running at 4.2 ghz on air with a noctua nh-d14, my score with vuemark is 345, which is around 3.5 times faster than my qx6700 was) so it's definitively a nice processor.
Right now only  a dual xeon 5680 (which would be roughly four times more expansive due to the processors themselves, the ECC memory and the motherboard) is faster (about 1.6 times faster)
MarkHirst ( ) posted Mon, 17 May 2010 at 2:00 PM
My new i7 930 powered machine has four processors, but Vue 8 Complete sees 8 CPUs and certainly uses them as Task Manager shows only too well !!
Hope that helps.
www.CambrianMoons.com
ddaydreams ( ) posted Mon, 17 May 2010 at 2:11 PM
Thanks for mention that.
I'm still hoping that someone will know the answer to what I had asked.
I'm still wondering if a i7 6 core will be seen as 12 in Complete or if the 6 will only show as 8 because the 8 core limitations of Complete.
MarkHirst ( ) posted Mon, 17 May 2010 at 3:24 PM
I was pointing out that hyper threading means each physical core is seen as two CPUs by Vue.
The product comparison table says 8 CPUs for 64 bit machines, that's why I went for the i7 930 rather than the one you are considering.
ddaydreams ( ) posted Mon, 17 May 2010 at 7:07 PM
Quote - I was pointing out that hyper threading means each physical core is seen as two CPUs by Vue.
I suspect that the 8 CPU limit of vue 8 complete is referring to physical cores not the virtual ones.
But I won't  know for sure until someone with an i7 6 core running on Vue 8 Complete chimes in says how many cpus are showing. It's either going to top out at 8 which would be 6 physical and 2 virtual.
Or it's going to be 6 physical and 6 six virtual total 12 if the Vue 8 Complete only counts the 6 physical cores towards the 8 cpu limit.
Because it would be waste of money to get a six core i7 if V8C can't use it fully.
Rich_Potter ( ) posted Tue, 18 May 2010 at 4:25 AM
if a 4 phsyical 8 logical cpu is seen as 8 cpus in vue, why would a 6 physical 12 phsycial only be seen as 6?
perhaps you should ask e-on for a definitive answer.
Rich
http://blog.richard-potter.co.uk
