Fri, Jan 24, 5:23 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 20 11:31 am)
Carrara Free Stuff here.
Subject: graphics card or cpu/ram?
benign_lump ( ) posted Tue, 18 May 2010 at 9:55 AM · edited Fri, 24 January 2025 at 5:21 AM
Which is more critical for rendering in Carrara, the graphics card or the CPU/ram? I'm going to be building a modestly priced computer - does anyone have any card recommendations. Will probably get 4 to 8 GB ram and Win 7 64 bit, upgrading to C8 when available.
Thanks,
Mike
MarkBremmer ( ) posted Tue, 18 May 2010 at 10:07 AM
 Graphics cards have nothing to do with rendering - only on-screen presentation. As always, when it comes to CPU speed and RAM, more is always better.
sparrownightmare ( ) posted Tue, 18 May 2010 at 10:14 AM
You want as fast a CPU as you can get.  I always use AMD CPUs.  They tend to be faster and a lot less expensive.  Also get as much RAM as you can possibly afford (up to the max supported by your motherboard.)  And make sure it is the fastest your MB can handle.  Oh yeh.  A multicore CPU really does speed things up quite a bit.  AMD has up to 6 cores now on their Phenom II 64Bit chips.  As for the graphics card.  That has nothing to do with rendering.  But you always want to get a decent card.  I use a Sapphire ATI 4870X2 HD 2GB PCIE card and it looks great.
I use an MSI 790FX-GD70 Motherboard with a Phenom II X4 X64 CPU, and a full 8GB of system memory (Corsair).  A system like mine is not top of the line, but it is a very respectable rig for 3D work.  And you could probably put one like mine together for a pretty low price now.
Hope this helps.
Quote - Which is more critical for rendering in Carrara, the graphics card or the CPU/ram? I'm going to be building a modestly priced computer - does anyone have any card recommendations. Will probably get 4 to 8 GB ram and Win 7 64 bit, upgrading to C8 when available.
Thanks,
Mike
benign_lump ( ) posted Tue, 18 May 2010 at 10:25 AM
Thanks for the quick replies!
I'm not going top of the line either, but I am going to pack as much ram into the new machine as I can.
Thanks again,
Mike
SilverDolphin ( ) posted Sun, 30 May 2010 at 10:46 PM
There are two AMD 6 cores the slower 2.8 ghz is $100 dollars cheaper.  I would spend the extra money on ram.
Just my 2 cents
ren_mem ( ) posted Wed, 02 June 2010 at 2:11 AM · edited Wed, 02 June 2010 at 2:15 AM
Amd doesn't currently have a hyperthreading equivalent  so some loss there. But that is always weighed against cost and performance. Ram on video doesn't help unless you are using cuda or opencl, so 512mb would be good, this would make previews a bit better. Get at least opengl 2.0 compliant. Get at least 4gb of ram, more if you want.
No need to think outside the box....
    Just make it invisible.
benign_lump ( ) posted Wed, 02 June 2010 at 6:40 AM
Went with a Core 2 Quad core and 8 GB ram (only 6 GB working, that last stick gets me a blank screen, may be bad) and Windows 7 64-bit. Only things I kept from the old machine are the hard drive (brand new anyway) and the GeForce 9500 1 GB card, which should do just fine.
Again, not top-o-the-line, but will blow away my old system. My first build, lots of fun, learned a lot, and most importantly - it works!
Haven't had time yet to see how C7 Pro works on it, but I'll get to that. Still deciding when to upgrade to C8 Pro.
Thanks all,
Mike
ren_mem ( ) posted Wed, 02 June 2010 at 5:30 PM · edited Wed, 02 June 2010 at 5:31 PM
Good to know. All ram should be same specs, works best, especially if doing any kinda dual channel. However, If you tried different configs of the ram and test w/ memT  that can tell you better what is going on. Depending on setup options you don't always have control in bios over timing/voltage tweaks so you get stuck w/ defaults. Certain ram just doesn't do well w/ certain mb's. Better quality ram in gen is more compatible. Dual channel kits can actually be headache savers.
