Tue, Dec 3, 6:35 AM CST
Vue F.A.Q (Last Updated: 2024 Nov 30 5:12 am)
Subject: Road material in Vue 8 help
mynodelic ( ) posted Thu, 20 May 2010 at 8:12 AM · edited Tue, 03 December 2024 at 6:34 AM
 hello! i'm a newbie here! and am a newbie to vue too! i want to animate a car on a road in the moutain. so i generate a moutain in geocontrol2 and then export it for vue...now coming to the road texture everything looks blurred and pixelated(as shown in the pic). If i tried to put the highway from the ecosystem and still nothing appears. Does anyone know how to solve this?
Thanks in forward :)
Rutra ( ) posted Thu, 20 May 2010 at 8:28 AM
If you're a newbie, I'd suggest that you start your "vue carrier" with something a little less ambitious... ;-)
The road texture seems to have too low resolution, hence the pixelated look.
If you want to animate a car, I don't understand why you need an ecosystem. All you need is a car object and move it along the road.
mynodelic ( ) posted Thu, 20 May 2010 at 8:41 AM
 well i need it for my senior project. this map is 10k x 10k .
i tried the ecosystem to see if the highway map works then i replace it by a map that i made. but that didn't work.
So any way to fix that?
FALCON2 ( ) posted Thu, 20 May 2010 at 9:58 AM
First for clarification :: From your post am I correct in thinkning that your heightfield map is 10K in size? Are you using a color variation to 'paint' your road surface?"?
Second - in general :: try activating interpolation for your maps that have pixelizxation bilinear or bicubic (gausian qwill anihilate the details in this case so dont try that mode)
Third -- for a dif. approach :: Why not use function driven procedurals, or again a mapped procedural mixing in a tiling image - if you really want the image mapped version (edge repeat only for the map).
Keep us updated!
Regards,
AF
mynodelic ( ) posted Thu, 20 May 2010 at 11:44 AM
hey thanks for the reply . I'll tell how i made this until i get back home and upload the maps so first i export the terrain map from geocontrol wich i made the road in it. The an alpha for the road...in vue i made a procedural map then a mixed material which hav an eco system instead of the blue color in the pic..and the material 2 has the alpha of the road and naterial:a map based on a bitmap which i made. This bitmap is from the road alpha..i enlarge it to 10k cuz i thought that would remove the pixels but that wasnt the solution...btw the alphas are bicubic and materials are object parametric...i dono if that explained it all but am writing on my phone :p anway i made a small texture myself but i dono how to make it follow the alpha and how the tiling works.....
mynodelic ( ) posted Thu, 20 May 2010 at 7:00 PM
 hey again thats the procedural texture map of the road. and where i want to add the tile shown in the picture... how can i do that ( straight forward :P)
@falcon2: how can i use ur thirds thing you mentioned?? thats wat i wanted to do but i don't know how.
thanks again !
mynodelic ( ) posted Sat, 22 May 2010 at 5:12 AM
ok! no idea anymore :P so just had one idea but i don't know how to do it : can i make the tile follow a path? or i should do it on photoshop ( cuz on photoshop it will look blurry )
thanks
FALCON2 ( ) posted Sun, 23 May 2010 at 9:50 AM
Sorry been swamped of late!
To clarify my thinking,
1 - using procedurals to enhance your image maps - this can help obscure any pixelization in the shots (both AsileFX & GeekatPlay have tutorials that can help w/that aspect of things).
2- as for the tiling comment, I had initially thought that since you'd defined a meterial region for the road, why not apply a single instance of the road image and tile it along the -X- axis - feeling that using a smaller but 300DPI image and tiling (w/interpolation of course)  would have helped a lot plus adding the function driven mix between the two should have completed the look you were after. Sadly taking more than a moment to think this one thorugh, image maps for the overal road surface might not be the best approach. Perhaps discreet material zones for each color/material on the road surface, then you can create tiling surfaces that sould work again w/teh caveats from above about image maps.
mynodelic ( ) posted Mon, 24 May 2010 at 9:46 AM
Quote -  Perhaps discreet material zones for each color/material on the road surface, then you can create tiling surfaces that sould work again w/teh caveats from above about image maps.
how can i do this? can u help me doin it ?
thanks a lot :)
DAM3D ( ) posted Mon, 24 May 2010 at 3:23 PM
 I would create the road with elevation in a 3D app, like Rhino, or whatever you like to use.. Then export it and texture the road with UVmapper, apply the texture and save it as an OBJ, then import it into Vue and make a terrain flat under the road, go into the terrain editor and raise the terrain to the road. done.
 My Rendo-Space
Do you know where your towel is?! I love Vogon Poetry. :P
DON'T PANIC!
Portland Pirate Festival Arrrr!
mynodelic ( ) posted Mon, 24 May 2010 at 3:26 PM
 and then i export it back to 3dsmax? because at the end the animation will be in max.
DAM3D ( ) posted Mon, 24 May 2010 at 3:29 PM
 I really don't know anything about 3ds max. But you could export it from Vue yes.
 My Rendo-Space
DON'T PANIC!
mynodelic ( ) posted Mon, 24 May 2010 at 3:33 PM
 okey! i'll try this even though i no nothing about uv mapper. but i'm downloading it now. thanks
