Fri, Nov 22, 2:28 AM CST
Subject: AO Strength on Material
Vex ( ) posted Tue, 25 May 2010 at 8:04 PM · edited Fri, 22 November 2024 at 2:17 AM
I can't quite figure out how to control the AO Strength on material nodes?
the strength value in the AO brick doesn't change anything
hborre ( ) posted Tue, 25 May 2010 at 9:07 PM
Actually, if you are using P7 or higher, use light-based AO.  The improvement in the lighting system has made it much better.
Vex ( ) posted Tue, 25 May 2010 at 9:16 PM
 yeah sometimes it doesn't play too well with hairs though, which is why i wanted to put it on skin.
Snarlygribbly ( ) posted Wed, 26 May 2010 at 5:16 AM
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?message_id=3195529&ebot_calc_page#message_3195529
The Strength parameter is broken.
Strength in material based AO can be controlled using the technique described in the attached link.
Free stuff @ https://poser.cobrablade.net/
