Forum Moderators: Staff
Attached Link: http://market.renderosity.com/mod/forumpro/showthread.php?thread_id=2735605
The correct keyword is actor, rather than prop. If you use the form actor $CURRENT, the pose will apply to the currently selected item - but this only works in Poser 5 upwards.Les Bentley's Compendium of PZ2 techniques (linked) is the bible for this sort of stuff. :-)
DAZ|Studio is more forgiving of this sort of thing, because it was developed after a lot of the community-devised techniques that we now take for granted (ERC, MAT poses etc.).
Thanks for the link - very clear and concise explanations.
I've fixed the .pz2 as suggested and it's fine, provided that I've also got a figure loaded (as Les points out).
I also resorted to RTFM, where it mentioned MAT pose files and MC6 files. Converting my MAT pose file to a materials collection (changing the extension from .pz2 to .mc6, changing "prop Stupa" to "mtlCollection", and moving the file from /Pose/ to /Materials/) seemed to do the trick.
So maybe I'll also convert the MAT poses to .mc6 files as well, just to cover the eventuality of no figure in the scene.
The 3Dcheapskate* occasionally posts sensible stuff. Usually by accident.
And it usually uses Poser 11, with units set to inches. Except when it's using Poser 6 or PP2014, or when its units are set to PNU.
*also available in ShareCG, DAZ, and HiveWire3D flavours (the DeviantArt and CGBytes flavour have been discontinued).
MC6s work better in Poser, but I'm not sure if D|S will accept them. You could always provide PZ2 style MAT poses for D|S users.
You also need Poser 6 or later to use MC6s, so you are cutting off a (probably small) part of your potential Poser-using audience. I tend to assume that people who are still persisting with older versions have enough know-how to apply materials by hand, anyway. ;)
Help!
I've created a simple prop model (.obj and .pp2 files) that seems to work fine in both DS3 and Poser6.
I've created a very simple MAT pose file to simply change a texture - here's the full file:
version
number 6
prop Stupa
material Plinth
textureMap ":Runtime:Textures:3DCheapskate:Stupa:PlainBlack.jpg"
0 0
This works fine in DS3. But when I select it in Poser 6, nothing happens. No pop-up dialog saying something's wrong, just a quick flash of a "Loading..." message at the bottom of the Library panel, then the Windows "Exclamation" sound (which I guess is Poser telling me that something's wrong).
Here's the stripped down .pp2 file that I'm using:
version
number 6
prop Stupa
storageOffset 0 0.3487 0
objFileGeom 0 0 :Runtime:Geometries:3DCheapskate:Stupa:Stupa.obj
prop Stupa
name Stupa
on
bend 1
dynamicsLock 1
hidden 0
addToMenu 1
castsShadow 1
includeInDepthCue 1
useZBuffer 1
parent UNIVERSE
creaseAngle 50
channels
propagatingScale Scale
name scale
initValue 0.1
hidden 0
forceLimits 0
min 0.001
max 100000
trackingScale 0.004
keys
static 0
k 0.1 1
sl 1
spl
sm
interpStyleLocked 0
translateY yTran
name ytran
initValue 0
hidden 0
forceLimits 0
min -100000
max 100000
trackingScale 0.001
keys
static 0
k 0 0
sl 1
spl
sm
interpStyleLocked 0
trackingScaleMult 1.000000
endPoint 0 2.0925 0
origin 0 1.04625 0
orientation 0 0 0
displayOrigin 0
displayMode USEPARENT
customMaterial 1
material Plinth
KdColor 1 1 1 1
KaColor 0 0 0 1
KsColor 0 0 0 1
TextureColor 0 0 0 1
NsExponent 96.0784
tMin 0
tMax 0
tExpo 0.6
bumpStrength 1
ksIgnoreTexture 0
reflectThruLights 1
reflectThruKd 0
textureMap ":Runtime:Textures:3DCheapskate:Stupa:PlainWhite.jpg"
0 0
bumpMap NO_MAP
reflectionMap NO_MAP
transparencyMap NO_MAP
ReflectionColor 1 1 1 1
reflectionStrength 1
locked 0
backfaceCull 0
visibleInReflections 1
visibleInRender 1
displacementBounds 0
shadingRate 0.2
smoothPolys 1
doc
addActor Stupa
Just in case it's relevant, the obj file contains 10 materials, each of which is laid out like this (nothing spurious in the file except an initial mtllib line):
#vertices
v -0.104169 12.826638 -0.043142
#UVs
vt 0.936161 0.944094
usemtl Plinth
s off
#faces
f 112/1 10/2 11/3 111/4
I'm probably missing something really obvious :oS
Like I said before - Help!
