If its only texture references then use Correct Reference from freestuff.
the relative path is the same no matter what runtime its in. It relies on Poser to look in each runtime using the path and then doing a full search if not. Setting a shallower search will pop up the message faster for you to point to the file. Check that the relative path is correct.
I think I have a script that checks everything but doesnt fix it. I will post it if I can find it.
Quote - If its only texture references then use Correct Reference from freestuff.
What if your textures are outside of your runtime? Also , what if you have the same textures on another drive? Everything was fine until my drive names changed...
We've all been there...
You load an item and then Poser goes into deep search mode looking for something, probably because you put it in a custom runtime and the author assumed it would be in the main runtime.
Yes, I know how to make it load... you go find the missing item and point poser to it.
The Question: What is the easiest method to solve this once and for all. I realize the Pz2 is going to have to be edited to show relative paths instead of absolute ones, but what do you edit and where is it in the HUGE* file? Better yet, is there a program that will do this for you? I'm fine with me having to find everything one more time... I just want to tidy all my files up so I never have to do it AGAIN.
