Thu, Nov 28, 11:06 PM CST
Subject: Michael 4 how to...
xpdev ( ) posted Thu, 03 June 2010 at 11:59 AM · edited Thu, 28 November 2024 at 11:00 PM
I'm use Poser 8 and i have downloaded M4.
I'm not able to remove the boxer to use Strideribellum M4.
Somebody can help me ?
Somebody use the Strideribellum M4 ?
many thanks.
Poser Pro 2014 SR 1 on Windows 7 64 bit
I use IDL, Gamma Correction and EZSkin for all final renders.
hborre ( ) posted Thu, 03 June 2010 at 12:10 PM
M4's boxers are part of his default skin textures.  Is the Strideribellum M4 a complete character with morphs and textures?
xpdev ( ) posted Thu, 03 June 2010 at 12:18 PM · edited Thu, 03 June 2010 at 12:21 PM
No, the Strideribellum M4 pack is for M4 genital.
I have understand what you mean, i have loaded the freack 4 skin and the short are invisible, that's ok.
The trouble is that the penis haven't the same skin...
hborre ( ) posted Thu, 03 June 2010 at 12:23 PM
And I am assuming that you have M4 morph++ pack installed as well.  That pack contains M4's genitalia.
xpdev ( ) posted Thu, 03 June 2010 at 12:26 PM
I don't know, if M4 morph++ became with standard pack (from DAZ), yes.
Faery_Light ( ) posted Thu, 03 June 2010 at 12:36 PM
Online Now!
you need to go into the material room, select the body, click the icon for changing the texture and browse to the" texturesdazcharacterm4" folder.
simply change to it.
hborre ( ) posted Thu, 03 June 2010 at 12:36 PM
I am unfamiliar with the Strideribellum pack and where I am currently, I cannot check the product thoroughly.  However, skin texture matching is a major problem with separate 3rd party products, and usually the only solution involves creating a texture map in a 2D program.
xpdev ( ) posted Thu, 03 June 2010 at 12:53 PM · edited Thu, 03 June 2010 at 12:54 PM
"M4Smpl_malebody.jpg"  that's ok, it work.
Can you tell me why i'm not able to see this textture from "libraries window" ?
hborre ( ) posted Thu, 03 June 2010 at 1:01 PM · edited Thu, 03 June 2010 at 1:02 PM
If it is a MAT Pose, you should be able to see an icon under the Pose Category of the Library.  If the product contains a mc6 or mt5 format file within it's zip, then you would need to apply the texture within the material room.  Usually Material room textures will have their own icons under the Materials Category.
Faery_Light ( ) posted Thu, 03 June 2010 at 1:08 PM
Online Now!
I checked my pose and material libraries and there wasn't any set for this texture so I just added it manually.
JenX ( ) posted Thu, 03 June 2010 at 1:49 PM
Attached Link: http://www.daz3d.com/i/3d-models/-/michael-4-morphs?item=7878&_m=a
> Quote - I don't know, if M4 morph++ became with standard pack (from DAZ), yes.
they are an add-on product that you have to purchase separately.
