Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 8:04 pm)
Very impressive. The webbing must have been a bitch to do. three groups x ten fingers = thirty morphs. Man, that must have been tedious. You can pull the verts all at the same time, and you can do one side and have MTM duplicate it for the other. But still, this is 15 separate pairs in MTM and 15 separation steps in EditPad. A bow and a heel click. You got ribs -of a sort- wish there was a higher mesh density on the ribcage. I would have opted for a prop, but then you loose the ability to bend the fingers and have the webbing follow. You could do a conforming figure, but this is as much work as the morphs (although I suspect that the cost in file size is about the same - morphs vs CF.) As an aside - How to I get www.jaager.com added to my spot on the PG Contributer's list?
Thanks all for your kind comments :) Jaager: that's right to make the Morph targets for each finger as a membrane one, was a pain :) well not really I used other method. BTW I added your site to our links and next to your name at the contributor members of the propsguild, thanks for share your URL with us. Glas: It suposed that there is a set of gills, but as Jaager said, the lack of polygones from Vicki's chest and collars made hard to get the right look of them, I'm working currently on it. Ken: Gracias por tus amables palabras en Espal para mi personaje, espero que pronto se encuentre cazando sirenas :) Thanks again to all for your kind comments. Best Regardings Benigno "Virus" Fernandez
SAL9000 - Hello Dr. Chandra, Will I've dream?
