Tue, Feb 4, 10:13 PM CST
Subject: Shut down after render ?
R.P.Studios ( ) posted Fri, 04 June 2010 at 4:48 PM · edited Tue, 04 February 2025 at 9:47 PM
Is it possible for someone to write a script/plug-in ect for this to be done ?
I wonder why Vue has not implemented this yet ?
I'd rather be hated for who I am, than loved for who I am not.
FrankT ( ) posted Fri, 04 June 2010 at 5:15 PM
if you use the external renderer, when the job starts up, there's a tickbox that is supposed to shut the PC down when the render queue is finished.  Dunno how well it works though
My Freebies
Buy stuff on RedBubble
Rutra ( ) posted Fri, 04 June 2010 at 5:44 PM
It works perfectly, I use it a lot.
DAM3D ( ) posted Fri, 04 June 2010 at 7:51 PM
 Yes I have used it, it works.
 My Rendo-Space
Do you know where your towel is?! I love Vogon Poetry. :P
DON'T PANIC!
Portland Pirate Festival Arrrr!
R.P.Studios ( ) posted Sat, 05 June 2010 at 3:48 AM
Even after using Vue for quite a few years, i do not know what about the external renderer. What does it use and depend on ect. ect.
FrankT ( ) posted Sat, 05 June 2010 at 12:36 PM
It's just the normal Vue renderer but it runs as an external process.  Good for rendering out big scenes if you are a bit short on RAM as you can close Vue and let the render carry on
My Freebies
bigbraader ( ) posted Sat, 05 June 2010 at 2:56 PM
I use the external render most of the time for final output as well, let's you work on your system with the render running "silently" in the background (of course the render may slow down a bit when you do "other things") .
DAM3D ( ) posted Sat, 05 June 2010 at 3:04 PM
 You can tell Hypervue to use just other machines on your network and not your main machine as well, that way all your other PCs are rendering your work and your main PC is not using any CPU so you can work on other stuff. :)
 My Rendo-Space
DON'T PANIC!
R.P.Studios ( ) posted Sun, 06 June 2010 at 5:36 AM
Well, I finally had the time to mess with it, and I havent found anything regarding shut down. I have only one machine, so network rendering does not pertain to me (;
Rutra ( ) posted Sun, 06 June 2010 at 10:53 AM
Click there while it's rendering.
hobepaintball ( ) posted Sun, 06 June 2010 at 11:00 AM
Is the external render engine robust? If a render takes my computer 20 minutes with standard Vue render, using external, with no other process running, does it take longer? It may save video card heating in my SLI rig
FrankT ( ) posted Sun, 06 June 2010 at 1:02 PM
it seems pretty robust to me, I often used to use it to render out images that I couldn't render inside Vue and it worked fine
My Freebies
DAM3D ( ) posted Sun, 06 June 2010 at 3:07 PM
 My experience with HyperVue so far has been great. It depends on the image, but basically, if I render an image on my main PC and it takes an hour, then render it again using hyperview with 4 machines working on the render, the render time is cut down to 17 minutes.
 My Rendo-Space
DON'T PANIC!
