Mon, Jan 13, 6:22 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: scene.Draw(), mouse and loops
georgevicbell ( ) posted Thu, 02 August 2001 at 11:45 AM · edited Sun, 12 January 2025 at 8:06 PM
Hey, Alright, I love this Python business...very easy to do lots of stuff...here's what I am doing, and the problem I am having... I am trying to make a realtime "puppet" using my joystick and poser, basically I have a loop, each time through the loop the puppet is updated based on the information from the joystick. Finally the loop calls scene.Draw() to redraw the screen. It works amazing, very fast and very smooth...only problem is, whenever the mouse is clicked (or as far as I can tell, whenever the OS tries to do something in the background) the scene stops updating....now I know that it is updating the character (from the joystick), I believe it is just not calling scene.Draw() correctly...as soon as the loop exits (click on joystick button) the screen magically updates and everything is in the place where it should be.... Any ideas on work-arounds (maybe disabling the mouse)???
jbrugion ( ) posted Thu, 02 August 2001 at 6:36 PM
Can you post the script? Did you try using scene.DrawAll() ?
georgevicbell ( ) posted Thu, 02 August 2001 at 8:52 PM
There's the script, just need to d/l the support files for the joystick at: http://www3.telus.net/futility/futility/docs/pysdl/index.html
JBSpence ( ) posted Wed, 10 October 2001 at 4:00 PM
I've tried this script, and the problem seems to be how often you ask for a Draw(). I put in an if statement to check if the values from the joystick had actually changed. If they had, I update the parameter values, then called Draw(). It works well, even with other programs running in the background. Regards, Jesse
Director ( ) posted Mon, 22 October 2001 at 2:49 PM
Wow this morning I was just thinking about this very same project that was mentioned a while ago.
GWeb ( ) posted Tue, 04 January 2005 at 4:38 AM
Can someone please post a working PY script?
