Sat, Jan 11, 8:52 AM CST
Subject: Is there a way to hide dials that aren't needed in a .cr2?
LaurieA ( ) posted Thu, 10 June 2010 at 11:30 AM · edited Sat, 11 January 2025 at 8:40 AM
I have a project I'm working on and I need to hide some dials in a .cr2 that aren't necessary. How would I go about doing that?
Thanks a bunch :o)
SamTherapy ( ) posted Thu, 10 June 2010 at 11:34 AM
I know there is a way but I don't know how to do it.  I believe you have to edit the cr2, probably using, uh, CR2 Edit or some such.
That said, I was advised against it by billy-home, who says hiding dials can cause all kinds of problems if you try to use the figure in other apps.
Simplest solution would be to keep them but disable 'em.
markschum ( ) posted Thu, 10 June 2010 at 2:09 PM
edit the cr2 and change hidden 0 to hidden 1 on any parameter dial you want to hide.
this is what a parameter section looks like
        valueParm PBMAreolaSize
            name AreolaSize
            initValue 0
            hidden 0        <<<<<<<< change this
LaurieA ( ) posted Thu, 10 June 2010 at 2:23 PM
Thanks markschum :o).
magnemoe ( ) posted Fri, 11 June 2010 at 12:35 AM
Is it a script to show the scale dials, far to often they are hidden then they might be useful for adjusting.
markschum ( ) posted Fri, 11 June 2010 at 10:36 AM
There are a number of scripts to hide and unhide dials.
Cr2 editor will also do it, but i find wordpad and search to be faster
Markus_2000 ( ) posted Fri, 11 June 2010 at 12:13 PM
Dial Viz by PhilC
LaurieA ( ) posted Fri, 11 June 2010 at 12:21 PM · edited Fri, 11 June 2010 at 12:22 PM
Yup, markschum's instructions were very simple, I found the parts I needed right away with Notgepad++ and didn't need to spend any money ;o). Oh, and it worked too...lol.
Thanks again Mark!
Jules53757 ( ) posted Fri, 11 June 2010 at 3:45 PM
Daz had, years ago, a tool for free, called DialCleaner V0.95. It was free but obviously no longer available :(
Ulli
rjjack ( ) posted Fri, 11 June 2010 at 5:12 PM
Quote - Daz had, years ago, a tool for free, called DialCleaner V0.95. It was free but obviously no longer available :(
still available @ http://free.daz3d.com/ you need an DAZ account to enter, dialcleaner is on page 7
