Mon, Feb 3, 10:24 AM CST
Subject: Vicky Catsuit - Lingerie
Tired ( ) posted Sun, 15 July 2001 at 11:36 PM · edited Mon, 03 February 2025 at 9:01 AM
I working on a lingerie type texture for Vicky's Catsuit. I'm still in the early stage and need opinions on the seam positions for the back of the suit. Which looks best A, B, or C.
otaku ( ) posted Mon, 16 July 2001 at 12:58 AM
My vote would be for C, although i think the mesh pattern might look better if it were a little tighter maybe 75% of what it is now and maybe also reduce the seem size by the same amount. All in all a very good start can't wait to see the rest. Might I also suggest when you get to the torso to have 3 versions for the top. 1 that stops just above the breasts, 2 that is more of a halter top style and 3 a full catsuit that includes arms and feet. OTAKU
Tired ( ) posted Mon, 16 July 2001 at 1:26 AM
Thanks, OTAKU - And I'll keep you're suggestions in mind.
etep ( ) posted Mon, 16 July 2001 at 4:08 AM
i think c as well, it follows the contours of the butt nicer, with the cross over just a tad higher
Tired ( ) posted Mon, 16 July 2001 at 4:09 AM
etep - by the cross over you mean the leg and hip seam, correct?
etep ( ) posted Mon, 16 July 2001 at 5:10 AM
yes, the leg and hip seam, if u raise the cross over slightly it would be less distracting?
Tired ( ) posted Mon, 16 July 2001 at 7:45 PM
Give a day or so to work on this, then check back. Thanks, folks.
Tired ( ) posted Tue, 17 July 2001 at 4:00 AM
Is this getting closer to the mark? The image on the left is "C" from previous image. The one on right has thinner seams, the cross over raised a bit, and a better lace texture in my opinion. What do you think?
otaku ( ) posted Tue, 17 July 2001 at 1:08 PM
Seams look better and I like the new lace texture as well. although i would still want the option of traditional fishnetting, similar to the original only a smaller pattern like I mentioned before. Keep us informed I look forward to it's release.
Tired ( ) posted Thu, 02 August 2001 at 10:19 PM
Etep and Otaku, - thanks for you advice. Still working on this project. Otaku, check out the girl in center. Does her fishnet work for what you're looking for. If so let me know and I'll send you a copy of the texture. Same goes for you Etep. If you like let me know which ones you're interested in and I'll email you the texture. Later
otaku ( ) posted Thu, 02 August 2001 at 11:29 PM
They look great. I don't know if you changed the size of the mesh, but it looks perfect in this rendering.
webdancer ( ) posted Thu, 30 August 2001 at 8:41 AM
Is the texture available? It looks wonderful.
