That's the first time I've heard of the spray-can rendering better then the main engine. :/ DOH. What version of Bryce ? Only thing I can think of is on the Document Setup. (bryce 4). Will leave this one for the Bryce masters out there. :)
The doctor says I have way too much blood in my caffeine system.
Have you done a final "real render" of this object with it's textures? When I do a quick test render or use the spray can textures can tend to look bad, and not things aren't defined. And do you have dithering turned off? I would keep it on, it blends colors much better. The spray can renders never look right, it just lets you see what your doing while your working. I'd like to help, but I need to know if you have rendered it for real? kaom
I did turn the anti-a. on with superfine. I took it off fast preveiw mode and it didn't do anything different. Where is the dithering? Also, I am using bryce 4 with the 4.01 update if that helps at all. I'm still new to most of this stuff so if I have to do something else to the rendering, it would help :)
Attached Link: http://www.renderosity.com/messages.ez?ForumID=107&Form.ShowMessage=359117
Turn off the objects antialiasingThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
