Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 09 2:14 am)
Attached Link: Alverson's store
Need a Tavern? or perhaps a simple room, or maybe even a full house? Want to have the choice of the parts you want on the image? The Tudor construction kit is the kit for you. This 11 piece set with textures will allow you to create and fashion as much or as little of a background set as you require, or want. Each prop is multi-materialed so cross beams can be set invisable in the materials editor, Each mateirial is easily named for retexturing (Like if you wanted a upper level shot and you need a stucco wall without the bricks) merely set the brick material to the stucco texture, and presto a solid stucco wall. The texture mapping is all based as a planar map so any square texture you wish to try will work. So you could go with tudor, to deco if you have the textures. and as an added bonus an additional tudor set including stairs railings, door and stop will be provided for free (Once your purchase is recorded)
