Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 3:39 am)
What OS are you using?
I had problems with this product as well and it turned out to be the textures for the water, which are AVI files. If you are running a 64bit OS you need the 64 bit codecs (video drivers) for these AVI files to be able to use the product. It turned out that there are/were no 64bit codecs for these AVI files. I then used a video conversion utility to convert the AVI files to ones with a 64bit compatibile codec. After that it rendered as it should.
Attached Link: AVI animated water
Usually, you want diffuse, specular, and ambient to total about 1, allowing a bit more for the specular.Try diffuse 0.6
specular 0.5
ambient 0.125
...and see what happens.
Actually, I would probably also drive the displacement with the movie (try 0.007 to start), remove the specular entirely, and add an anisotropic (node:lighting:specular:anisotropic) and set the color to charcoal grey 64-64-64 RGB. The anisotropic can give you nice water sparkles. ^^
Oh, and un-check the reflection Lite mult box.
The hotlink is a little flash clip using one of Jepe's water AVIs.
OSes: Win7Prox64, Win7Ultx64
Thank you so much! It is sure looking better! I will have to change the other nodes.
I never would have come up with those settings. I was trying to make only minimal changes to the default material settings that I showed since it did look ok in P7. But with your settings I think it will look fantastic in P8.
Thank you also for the link that showed what the water should look like. Your animations always look great and as much as I loved horserider, Tink on roller skates is still my favorite. :-)
This is what is happening:
www.lilwolff.com/Free/WSPoser8.jpg
This is the product.
market.renderosity.com/mod/bcs/index.php
I did write the author but I have not heard anything and it has been a week. Perhaps they are on vacation? I am not familar with this vendor's support and I do need to get this project done.
I know it says 6 and 7 - I just don't understand why the water won't work in P8 when everything else does? . Whether I use my old pz3 or start a new scene in P8 I get the same results.
Attached is the settings for Poser 6 and 7 for the small falls that you see is white. I used the lights and camera settings that came with the product. I don't need an animation just a still.
Thank you for any help you can give me.
