Carrara F.A.Q (Last Updated: 2025 Jan 04 8:20 pm)
I dont see any problem to use it in the 32bit system, you will receive a new key and it will be installed in a new directory...
Follow me at euQfiz Digital
Does easypose work in C8? I ask because my experience with C7Pro is that it works sometimes and sometimes it doesn't.
Also, I bought C8 but have hesitated to install because I am still on a 32 bit system (XP 32 bit) and am contemplating buying a new system with W7 64 bit. Will I run into problems if I install it now as 32 bit, then later as 64 bit? It's an upgrade, so I assume I'll be using my current C7Pro license.
Klebnor
Lotus 123 ~ S-Render ~ OS/2 WARP ~ IBM 8088 / 4.77 Mhz ~ Hercules Ultima graphics, Hitachi 10 MB HDD, 64K RAM, 12 in diagonal CRT Monitor (16 colors / 60 Hz refresh rate), 240 Watt PS, Dual 1.44 MB Floppies, 2 button mouse input device. Beige horizontal case. I don't display my unit.
