Fri, Nov 22, 10:58 PM CST
Subject: Know issue or just my luck? Is the Joint Editor broken in PP2010?
TrekkieGrrrl ( ) posted Wed, 14 July 2010 at 11:37 AM · edited Fri, 15 November 2024 at 12:45 AM
 I've tried a few times now, and as soon as I even touch a joint zone with PP2010's joint editor, the whole thing scoots out into space, messing up the garment completely.
If I try the same thing in Poser 8, it works as expected.
Is this a known issue?
pjz99 ( ) posted Wed, 14 July 2010 at 12:35 PM
I don't think you're the only one who has reported this in Pro2010.  P8 does seem to work fine though.
My Freebies
magnemoe ( ) posted Thu, 15 July 2010 at 4:38 AM
I have the same problem, centre fall to the floor then you try to edit anything.
As I understand it’s happening then you use comma as decimal separator, change to . then using it or use an older version of poser. Will probably be fixed on the first update.
TrekkieGrrrl ( ) posted Thu, 15 July 2010 at 6:43 AM
 Ah so PP2010 is ALSO a victim of the Comma bug? Sheesh one should think they were getting fed up with fixing this...
Has anyone heard of the chances for a ServiceRelease for PP2010 before it's suddenly 2011?
nruddock ( ) posted Thu, 15 July 2010 at 2:16 PM
Quote - Sheesh one should think they were getting fed up with fixing this...
Can only be answered with :-
Quote - Those who cannot remember the past are condemned to repeat it.
Which for programming means if you don't update your testing regime regressions like these will always reoccur.
