Wed, Dec 4, 6:14 AM CST
Vue F.A.Q (Last Updated: 2024 Nov 30 5:12 am)
Subject: Poser->Vue7xstream-> Max issues
sdmakai73 ( ) posted Fri, 16 July 2010 at 3:35 PM ยท edited Thu, 25 July 2024 at 5:48 AM
If someone can help it would be great. I created a posed figure in Poser imported that into VUE7 for a render, (which is fantastic) but I want to export that scene to Max so I can rig the character for animation. When I try to export scene it says some objects are locked from export. narrowed the error down to the imported poser scene, as I can export any scene created without the poser import fine. IS there anyway around this, or do I need to start over?
In a nut shel the scene I created in VUE with the poser import is perfect for a animation render and animating in VUE is quite time consuming. Thought it would be easier to export the entire VUE scene and rig the figure for use with BIP files.
Is there a better way to do this?
sdmakai73 ( ) posted Fri, 16 July 2010 at 3:41 PM
Solved. It's under edit objects. There is a botton for locking objects from export for those who come across the same issue.
