There isn't really any reason to actually EXPORT from Poser, just import the base OBJ file that Poser reads in the first place. There are problems with Poser's OBJ export that you don't really need to bother with unless you really need to deal with the Poser target state (posed rig or morph target). What exactly are you trying to do?
The base OBJ file is "C:Program Files (x86)Smith MicroPoser 8RuntimeGeometriesDAZPeoplebl_MilWomV4b.obj"
Yes I did the direct Import also. It's the same result. The parts are not listed in LW.
Frankly speaking, I am trying to get used to all this modeling etc. For learning I put the head and neck of V4 as a reference into two LW background layers. Then started to model a scull cap based on that reference. I use two layers to understand the LW layer concept and to have a reference where the head and neck part start and end. It worked fine so far (markschum told me I have to be in Poly mode to get the part list). I was able to select the head polys and the neck polys, copy and paste each one in a different layer and was happy. My modeling of course went out to be a complete mess so I had to start from the beginning. But now I can't get those V4 parts in LW anymore (I am sure I am doing something wrong, but I can't figure out what).
By the way I tried with
Use file, load object to bring the obj file into LW.
You can confirm this by loading the obj from the runtime/geometries folder.
You will get the parts list in any mode , but to cut and paste them you need to be in polygon mode. Selecting vertex only for a cut and paste will work , but isnt what you want to do.
If parts dont show on a poser export then you need to look at your export options.
My default export is weld body part seams , and include body part names in polygon groups
you can check your obj file by opening it in wordpad or other text editor , and looking for lines starting with g thats the group name usemtl is the material (surface) name.
It sounds like you may need to log a bug report with smith micro.
That option you have greyed out is greyed out in poser 7 as well.
you could try export as lwo from Poser. I am not sure what you will get in Lightwave but it might be worth a try.
If you imported the base OBJ into Lightwave and you can't see groups, then your problem is not with Poser at all, it's with your import procedure in Lightwave. I guarantee you the groups are present in the base OBJ, and Poser can't have anything to do with whether or not you can see those groups in LW. You haven't overwritten that base OBJ have you?
or does it interpret it as - "search for the xxx.mtl file and read the values out of that one"?
Anyhow I will now go back to another LW version and try with that one.
"usemtl" entries in an OBJ file define polygon selections that are associated with a given material (in OBJ format, very limited info, and specified in *.mtl as I think you were already figuring out). Definitely something is not right with your LW import, whether it's just an option you can fix or something more serious I don't know.
But now I have to face, that I don't really understand OBJ. What is a part, what is a surface, what is a group (Poser) etc? What happens when exchanging between Poser, LW, Blender, Wings, 3DCoat etc?
Do you know a ressource where this is explained in more detail? It would help to do less guesswork? I'll also google to find something.
Oh glad you got it figured out :) Wavefront OBJ is an orphaned file spec but it's pretty widespread. If you search around you can find a variety of writeups on how it works, google for "OBJ format file spec".
http://www.martinreddy.net/gfx/3d/OBJ.spec a good version
nb: since OBJ isn't really managed from an authoritative source any more, it's pretty common that different apps will import or export OBJ with a lot of variation in what features are supported or how they're implemented.
Surface is what Lightwave calls a material.
In the obj file a part is a group which is identified by the g lines
a surface is a material identified by a usemtl line
the usemtl and g lines identify which polygons are allocated to those groups. All polygons until another g or usemtl are allocated.
the .mtl file provides the parameters for the named material, but only some of them.
good to see you have it sorted out.
a bug that might still be in Lightwave is the UV information. LW used to discard UV info if the surface was not attached to the uv map in the surface editor. You need to open the texture editor T on the diffuse and specify map type UV and the map name. You dont need to actually have texture applied , just the map. You can tell if your uvs have been lost by either looking in the obj file for vt lines or open the obj in the free uvmapper utility.
Now you probably want to figure out how to get it going the other way (do your grouping and other polygon selections in LW instead of working with Poser's nasty grouping tool).
Now, whatever I do, I don't get the parts anymore. Only the surfaces (skin face, skin legs etc.) are available in the statistcs panel in LW.
When it worked last time SR1 for Poser 2010 Pro was not installed.
Now the SR1 is installed.
But I don't know if this has something to do with it or if I am just doing something wrong.
Maybe somebody can help me with this?
OT - Is it possible to put the image below the text intead of above it?
