Sun, Nov 24, 3:14 AM CST
Subject: Poser external render engine povray / poseray
xuu4u ( ) posted Mon, 02 August 2010 at 10:45 PM · edited Tue, 10 September 2024 at 7:53 PM
Well there is so much discussion about the lux renderer and the poser exporter for lux at the moment. Years ago i tried to render Poser scenes in Povray. Results wasnt satisfaying, but i didnt try to much and my knowledge about 3D was just in the beginning. This  thread (http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2807395) remembered me povray. Searching via google, i found: Povray 3.6.2 64bit PoseRay 3.12.2 / PoseRay3.13.4_beta
After dowload and installing, I took a pp2010 Scene and exported it to .obj
Loaded scene.pzz  and .obj to PoseRay without Problems.
Then using povray export & rendered it with povray (pure defaults, nothing changed)
It looks to me that there a lot of options in poseray and povray.
I would be very much interested in what others think about povray.
flyerx ( ) posted Tue, 03 August 2010 at 3:30 AM
Attached Link: http://www.povray.org/
The current POV-Ray beta 3.7 has many new features and fixes to radiositiy and gamma. PoseRay can work with POV-Ray beta 3.7.
Main limitations with PoseRay is the material transfer. Since Poser moved to the new material system in version 5 most of the material is hit and miss particularly on specular properties. I was not going to rewrite a material parser. Many complicated materials in Poser can be done with a single line in POV-Ray.
The key is to experiment and keep one thing in mind: If you do not use PoseRay to convert the scenes make sure they are scaled at least by 100 during the conversion. This way POV-Ray does not have problems with the very small scale Poser uses. PoseRay does this scaling by default.
FlyerX
ima70 ( ) posted Tue, 03 August 2010 at 8:24 PM
I experimented with the basics of the material lenguage (I don't know if it's the right name) and doing radiosity with skylight and really looks good.
this is a fast try at skin.
I've found this interested information about matials
library.thinkquest.org/3285/language/index.html
