Sun, Jan 26, 5:11 PM CST
Forum Moderators: Staff
Subject: PPro 2010 64 bit
LukeA ( ) posted Fri, 06 August 2010 at 6:58 PM · edited Sat, 25 January 2025 at 2:49 PM
How do I tell what version I am running, it doesn't say anywhere. Also after the install I have Poser 8, Poser Pro, and Poser Pro 2010. There are 2 versions of Poser Pro and Poser Pro 2010 installed too.
I know that Poser 8 is obviously not the 64 bit version but what is the difference between PP and PP2010 and the two versions of each?
Thanks
Luke
LukeA
My latest novel
nruddock ( ) posted Sat, 07 August 2010 at 5:01 AM
Quote - I know that Poser 8 is obviously not the 64 bit version but what is the difference between PP and PP2010 and the two versions of each?
If you chose the default installation location(s), by the Windows convention, the 32 bit version will be in "Program Files (x86)", the 64bit version in "Program Files".
LukeA ( ) posted Sat, 07 August 2010 at 10:50 AM
Thanks! I ran a test after I posted this to see if I could tell the difference by render speeds and I could :) WOW I have a Win7 64 bit machine with 12 gigs of RAM and you can tell :)
LukeA
My latest novel
