Sat, Jan 25, 11:13 PM CST
Subject: Poser Pro 2010 Library question
Thersidesus ( ) posted Fri, 13 August 2010 at 9:39 PM · edited Sat, 25 January 2025 at 10:57 PM
Hey all,
I sent a question to Smith Micro about this; but I'm hedging my bets by posting it here also.
My question is to see if I can get the poser library back onto the interface?  I"m just tired of re-clicking it back to the front over and over and over again (especially when doing clothing MAT's, it's just a pain in the butt).
That's all; if there's a way, I would really like to know (but I'm not holding out too much hope).
Thanks much in advance,
Thersidesus
hborre ( ) posted Fri, 13 August 2010 at 11:46 PM
You haven't given very much information about which Poser version you own ( I suspect PP 2010) and under which OS it is install to.
Bez ( ) posted Sat, 14 August 2010 at 3:31 AM
Check the 'Always on top' box in the General Tab right down the bottom of the Poser Library, that might help.....
raven ( ) posted Sun, 15 August 2010 at 10:44 AM
If you are on a 64bit operating system, then no, the library will always be a separate floating window. If you are on a 32bit system, then in General Preferences, select the Library tab and in the Launch Behaviour section select 'Embedded' and the library will be able to be docked like any other window.
Thersidesus ( ) posted Sun, 15 August 2010 at 11:49 PM
Thanks Raven; I am running on a 64 bit OS; guess I'll have to get used to it (blech).
