Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 31 9:20 pm)
I'm really not entirely sure what it is you're trying to do...
The objects in the geometries folder aren't to be used as-is...they are the meshes that the .cr2s for the figures and clothing point to. If you use just the object you can't pose anything.
Is it that you can't see the items in your library? If that's the case, you'll need to check your firewall and allow Poser to go thru the firewall. If it's not that, you need to update Flash.
I don't know what firewall you're using or even what OS, but there should be a list of programs inside your firewall program where you can allow a program access past the firewall or not. I'm not familiar with every one and since we don't know what firewall you use, none of us has any idea to tell you how to do that ;o).
If you import the OBJ into a scene, you will be able to see it in the scene document.
Poser does not categorize OBJ as a type for the library. You can save the imported OBJ as a prop (.pp2) and have in props folder for later use.
At this time, I do not believe problem is firewall related, but just lack of basic knowledge
Quote - Thank you for all of the help. I have finally figured it out. I have to go to libraries->select add library->browse->computer/programfiles/smithmicro/poser8
Not even close.
There are not supposed to be any content folders under main runtime. When you installed, it should have asked you where you wanted content.
Of course, you can have extra runtime libraries using method you described, but don't pick main runtime.
How do I download OBJ files that are in the Geometries folder into Poser 8?
I have tried copy and pasting the files and folders into Program Files-Smith Micro-Poser 8 but, the items still do not show up in the Poser Library
