Mon, Jan 13, 2:07 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
Subject: Help with Camera Controls
mach ( ) posted Tue, 17 August 2010 at 8:33 PM · edited Mon, 13 January 2025 at 8:40 AM
I'm running Poser 5 on a pc.with a vista os. I opened P5, loaded V4 removed the Ik and went to use the trackball camera control-the figure flew out of view. the same thing happened with the posing and face cameras. The tracking control is hyper sensitive-the slightest movement sends the
figure out of the poser window. This is the first time that I've encountered this problem.Does anyone know of a fix for this problem?
markschum ( ) posted Tue, 17 August 2010 at 10:55 PM
You can move the camera with the parameter dials, just select the camera from the dropdown list. Its a bit tedious but you can see if that works OK.  I have seen that problem before but it would never happen when I wanted it to, try restarting Poser.
Fugazi1968 ( ) posted Wed, 18 August 2010 at 2:59 AM
I had this problem with Poser Pro, was a right pain in the bum.  Some wise person here told me to press the Space Bar when it happened, which despite my scepticism worked a treat :)
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
geep ( ) posted Wed, 18 August 2010 at 4:31 AM · edited Wed, 18 August 2010 at 4:39 AM
This problem usually occurs after viewing a video and  before running Poser.
When it occurs, use the "Undo" function (if available) and then ...
Press the "space bar" ...
... this appears to clear the problem and then cameras work normally.
cheers,
dr geep
P.S. If "Undo" is not available ...
You can use the small arrowhead to the right of a parameter dial to "Reset" the parameter.
Do this for all of the camera's parameters that have abnormal or out of range values.
cheers,
dr geep ... :o]
edited 10/5/2019
mach ( ) posted Wed, 18 August 2010 at 2:31 PM
Thanks to all of you-the space bar and reset worked.
