Vue F.A.Q (Last Updated: 2024 Sep 26 4:27 pm)
Flickering is said to be much less in each release of Vue. I've been tricked twice now (with version 7 and then 8). So I'll wait until their is no flickering :).
Thank you all for the tips :-)
Daniel1705, that 's some good work (especialy the growing leaves on the tree)
I will look deeper into that tread and experiment with the settings as you described (this is my first animation too)
Although i used 25fps (as you also did) i think i will use a bit more fps because at 25fps it seems that it is not flowy enough (if that is even a word LOL)
Wim
Society failed to tolerate me...
... and i have failed to tolerate society
The broadcast setting is specifically optimized for animation. I'd try that render setting to start from, then if that doesn't fix the flicker enable user settings so as to be able to make some specific changes. Under Advanced effects, in the general tab, look for jittering and expand it's drop-down menu. For an animation, you want the reduced pulsation option.
OSes: Win7Prox64, Win7Ultx64
Hi gang :-)
I'm busy with rendering animations and selected the 'Final' mode render settings for this. I know there was a tread about this topic some time ago but i cannot seem to find it :-(
Can anyone point me to this topic or give some advice for render settings that will eliminate the flickering issue ?
I use Vue 7.4 Infinite
Thanks
Wim :-)
