Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 31 9:45 am)
Thanx, kawecki.
"Oh - the manual says that? I have never read the manual - this must be why."Quote - This uses sse2 so it wont work on my computer.
Damn, I never thought that it would be a problem, any some years old computer has SSE2.
In only one part of the software I use a SSE2 routine that has a tiny advantage over the previous SSE that still exist commented, I forgot to compile and put back the older SSE routine.
SSE2 in theory looks great, but in practice have very little advantage, if any, over the classic SSE/MMX..
Stupidity also evolves!
Well, five minutes work and I have updated the product.
Now when PropViewer starts it will check for MMX, SSE and SSE2.
For older coputers without MMX and SSE (before Athlon XP or Pentium III) nothing can be done.
PropViewer will display a message and then quit.
For not so old computers without SSE2 (before Athlon AMD64 or Pentium IV) propViewer will use
a SSE subroutine with very little difference in speed.
For new computers that have SSE2 PropViewer will use the SSE2 subroutine.
For whom has old computers and PropViewer refused to run, just download it again from the link above.
And for people that has downloaded and PropViewer is working, you can keep what you have, the new version will not make any difference.
It ask for a flm when you want to resume a rendering.
If you want to start a new render select Open under the file menu and then load the lxs.
When you want to save a render then stop the rendering, chose "save flm" and save it with the extension flm and not as lxs as LuxRender prompts (a bug).
To resume the rendering select "resume flm" then load the scene file (lxs) and next the saved flm and LuxRender will continue to render for more hours.....
It is easy to edit the camera.
Open the lxs with a text editor and you will find something like that:
LookAt -0.300000 -1.5000 0.6000
0.000000 0.00000 0.4000
0.000000 0.00000 1.00000
The first line is the camera location
The second line is where the camera points
The third line you can leave as it is.
Remember that the coordinates system is different, you must read
(left -, right +), (front -, back +), (up +, down -)
So the first line you read that the camera is at 0.3 to the left, 1.5 at the front and 0.8 up.
Attached Link: http://www.sharecg.com/v/43389/Poser/PropViewer-3.1-with-LuxRender-Exporter
A new version of PropViewer with new features. Now it is able to export to LuxRender. It is a stand alone application that doesn't require Poser or DazStudio to work. It only export meshes with materials with a default scene that can be easily edited with a text editor and a little knowledge about LuxRender. It is still experimental, but it works fine.For more details read the text files inside the package.
