Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
It all depends on the situation and whether or not an agreement was met by the original copyright holder and the brokerage that the violating product was in.
I know that here, if an item is removed for copyright violation, you will be told 1. Whether or not you need to delete it from your hard drive, 2. Whether or not other pieces of the vendor's work you may have are in violation.
There have been times (I don't recall if any of them involved Renderosity products, but, they happened) when the copyright holder has ok'd the further use of the purchased product OR a refund. Both DAZ and Smith Micro have ok'd use in that instance, but it's always a case-by-case basis, and it's always up to the original copyright holder.
Knowledge is knowing a tomato is a fruit. Wisdom is not putting it
into a fruit salad.
Oh, and in the case where one item of a vendor's store may violate copyright, but the rest of the store is clean, you're free, legally, to use what doesn't violate the law. However, due to site policy, once a vendor is found to have infringed copyright, their vendor status is revoked.
into a fruit salad.
Contact the store you purchased the product from. That's the only way you can really find out.
into a fruit salad.
If the product you're using is a copyright infringement, regardless of whether or not you, yourself, receive payment, you could still be held liable. HOWEVER, that would only be if the original copyright holder brings a lawsuit against you. I haven't heard of it happening yet, but, I'd hate to be the one they set the precedent against, you know? Why use a product declared to be a copyright violation when there are thousands that aren't?
into a fruit salad.
Well, my suggestion (remember, I'm not a lawyer, so this isn't legal advice) is to contact the original copyright holder, if the item you want to use was found in violation of copyright, and ask them for permission. It couldn't hurt, right?
into a fruit salad.
Attached Link: http://www.runtimedna.com/help.php?section=contactus&mode=update
Since he was sold at RDNA, I would double check with them on how to proceed. I don't recall whether or not bruizer was a problem, but they'd know more than we do.Sitemail | Freestuff | Craftythings | Youtube|
into a fruit salad.
ok yeah i knew where he was sold but i saw all of IE's products were pulled, ironically i was looking at some galleries on here and some used his/her he bot character. i tried to search around for the reason he was pulled but everything was extremely vague.
thank you- i will contact rdna and see if they can give some insight
and ty both for your help
Yeah...a lot of times, if a merchant is found to violate copyright, their store is pulled, whether the rest of the items are in violation or not. And, in the forums, you'll generally get a vague answer, because anything that's said can be twisted to mean something else entirely, so it's actually best to just go to the source ;)
into a fruit salad.
Maybe, but I'm not sure if the store that pulled them, or any others would take that person on again as a vendor.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
true- then again one can change name
oh yeah after rdna responsed, seems bruizer is "questionable" again vague solution
my theory is MK has a problem with the character which is understandable seeing as how my first thought was gorro. though i do find it slightly odd, poses for said character are still available
if a character or anything like that gets pulled for copyright infringment, are we still allowed to use it?
if so what are the limitations?
