Tue, Feb 4, 6:33 PM CST
Subject: BLENDER : export problem
jpcr ( ) posted Tue, 07 August 2001 at 7:29 AM ยท edited Mon, 03 February 2025 at 2:44 PM
it exports dxf bat vue 3.1 wont read it. did someone used it? jp
MikeJ ( ) posted Tue, 07 August 2001 at 8:22 AM
That doesn't surprise me. The DXF format has alot of variations, and I think Vue only reads a few of them. :(
MikeJ ( ) posted Tue, 07 August 2001 at 8:25 AM
Attached Link: http://www.stmuc.com/thbaier/links.html
Try this link. 3D Win is a 3D file convertor. It's shareware. You will probably be able to use it to load your DXF files into it and export out .obj or 3DS to use in Vue 3.1. I would recommend those formates over DXF any day.
MikeJ ( ) posted Tue, 07 August 2001 at 8:33 AM
Attached Link: http://www.us.righthemisphere.com/3dexploration/3d_exploration_home.htm
And there's also this program, 3D Exploration. The demo lasts for 30 days, but the license is about $200.00 to keep using it after that. :( This program is very good though. It used to be only about $40.00 until the good people at Right Hemisphere bought it!
jpcr ( ) posted Tue, 07 August 2001 at 8:44 AM
thanks, i'm trying crossroads , it works but gives a warning the 3ds format is old so it wont keep material. jp
MikeJ ( ) posted Tue, 07 August 2001 at 9:42 AM
If you mean that Vue is giving you that message, I don't know what the reasoning for it is, but Vue is wrong. I get that all the time after converting MAX files or PRJ files into 3DS, and materials always load, map, and render just fine. of course, Crossroads is pretty old, but if you're converting DXF files into 3DS, you aren't dealing with any materials anyway, since DXF doesn't have any UV mapping info in the format.
jpcr ( ) posted Tue, 07 August 2001 at 10:16 AM
THANKS, i'll go with crossroads. jp
