Jumping ahead to this part of the thread with a response to earlier posts... Laurie and all, they keep attributing most fireflies in the Reality thread over at DAZ to specular and glossy being too high. Bring those down and most go away, though some are still having problems. You can also use the dust and scratches filter with the threshold set to around 25 or so in Photoshop CS4 to get rid of them in a final render. You keep your detail but lose the fireflies if they aren't too big.
Kevin
Well I chose a very different approach to diffuse and specular values. I have them very low. When you put in
I'm doing a render now where I have 3 lights, each in its own group so I can manipulate the ratios and colors.
Only one of the lights has a firefly in it. The others are clean at 920+ samples.
The exported specular values are from LuxPose are in the range of .1 or less even if you used .5 to 1 in the Poser shader. The diffuse is .7 when you type in 1 in poser.
I just realized that I've been testing settings with modified multipliers. So the numbers I'm using won't come out the same for you guys until I release this updated mat converter.
Wanted to share with you guys that my Beauty vs Beast has been selected as a Staff Pick by the Poser team. :D
As it was rendered with Luxrender and exported from Poser using LuxPose, I just want to say, score one for the LuxPose team!
Thank you BagginsBill, ADP01, ODF and other contributors for making this software possible for us regular users. :)
http://www.renderosity.com/mod/gallery/index.php?image_id=2101465&user_id=627255&np&np
Software: OS X 10.8 - Poser Pro 2012 SR2 - Luxrender 1.0RC3 -
Pose2Lux
Hardware: iMac - 3.06 GHz Core2Duo - 12 GB RAM - ATI Radeon HD
4670 - 256 MB
So, in theory, it would probably take a good computer w/ 64 bit to take advantage of timing with this? Just asking.
BTW, excuse my ignorance, great renders you made BB and Flenser.
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
Jartz,
As long as your scene is not getting too crazy with glass and reflections render times to reach a good state should be comparable with a high quality Poser render.
A big plus of Luxrender is that within 10 minutes you'll have a view of your final image that will tell you if it is going to look good.
Pose2Lux
4670 - 256 MB
like Fleser said. in Luxrender you have different render settings.
if you choose the bucket options you need to whait almost the whole render to see the results. if you choose other render settings you can watch the whole render at low quality. this is fatastic to see the shaders and the lighting. you can change it very fast.
so you have an option to find your perfect light set up without making 20 test renders.
I messed up the eyes.
just wanted to say "hi" and apologize for being "AWOL" for the past few days.. my son turned 1 this past friday and we went out of town.. and my wife has a fit if I use my laptop while we're "on vacation" unless a client has an emergency :P
so, I'm back, and I'll gladly work on the website design and forum layout if you want :)
Downloaded latest exporter 1-14b and get this error
File "C:Program Files (x86)Smith MicroPoser 8RuntimePythonposerScriptsworkersPoserLuxExporter_workers.py", line 429, in write
print "NORMALS",params.compute_normals
NameError: global name 'params' is not defined
Poser 9 SR3 and 8 sr3
Processor Type: AMD Phenom II 830 Quad-Core
Hard Drive Size: 1TB
Processor - Clock Speed: 2.8 GHz
Operating System: Windows 7 Home Premium 64-bit
Graphics Type: ATI Radeon HD 4200
System Ram: 8GB
Quote - This isn't all that great, but not bad. I set it for a large render and let it run overnight. 10 hours, 2500 samples per pixel. Click for full size.
i think it would be better if you would use M4 or Apollo. because this is one ugly model. her body makes no sense and the texture is bad IMO.
adp, I redownloaded and I am still getting this error.
System Ram: 8GB
Thanks adp that fixed my error ;o)
System Ram: 8GB
The particulars are on the image.
I have no idea why I'm getting that ring on the floor and there are still a few blank pixels, but overall, I'm satisfied with the skin. At least she's not shiny...lol.
This particular skin does have a bunch of burned in highlights, but I only have two and it's the lesser of two evils. The Daz texture is horrible ;o).
the other one suffers from firefies too since it's a problem with LuxRender and not with the exporters ;o). Nevertheless, sometimes it renders ok. I can fix those pixels in PS likety split ;o).
Edit: here's what I notice about skin and LuxRender. Skin needs to be adjusted for just about every type of lighting and type of tone mapping. It doesn't look the same in all light or with the different kinds of tonemapping with the same settings in Poser. Hoping that can be changed, but if it can't, I'm willing to fiddle with it. I fiddle enough in Firefly, why not LuxRender?...lmao.
Quote - of course teh skin will look different with different lighitng and different tone mapping settings.
isnt this normal?
I just wanted to stress it in case some were thinking otherwise ice-boy. LuxRender is not a point and click solution. I don't care about click and render but some do.
I guess I should refrain from stating the apparently obvious from now on.
Quote - > Quote - of course teh skin will look different with different lighitng and different tone mapping settings.
isnt this normal?
Well actually it's not obvious to everyone, you keep stating things like that for those who don't know it already. :D
Windows 7 64Bit
Poser Pro 2010 SR1
Quote - the other one suffers from firefies too since it's a problem with LuxRender and not with the exporters ;o). Nevertheless, sometimes it renders ok. I can fix those pixels in PS likety split ;o).
Good job, Laurie! I'm hoping it never looks like it does in Poser! ;) Skin is looking so much better, especially what BB did a page or two earlier and your example here.
Quote - > Quote - the other one suffers from firefies too since it's a problem with LuxRender and not with the exporters ;o). Nevertheless, sometimes it renders ok. I can fix those pixels in PS likety split ;o).
Thanks. I thought odf's looked pretty durn good too :o).
Pose2Lux
4670 - 256 MB
Quote - I just don't want anyone to get any ideas about what LuxRender does or doesn't do. Some people will be disappointed, that's for sure.
not if they will look at the gallery on the official site from Luxrender.
if 90% posts are about realism and if someone ask if he can render stylized renders then he needs a slap.
Poser's firefly render engine is good enough for stylized renders. for realism we will use Lux.
I like this and I like the numbers - easy to remember.
