Quote - [
LOL. Nah, Lux files are almost human readable. Some parts of the syntax are strange-ish (I suspect they might make perfect sense to a developer - I'm not one), but if only there were a complete, up-to date documentation it would had been a piece of cake.
Why don't you start writing a documentation for users, not developers?
Quote - In poser 6 I get this error when running the python script.
:758: Warning: 'yield' will become a reserved keyword in the future
Traceback (most recent call last):
File "", line 157, in ?
File "workersmanageMaterials.py", line 9, in ?
import MatNodes5
File "", line 758
yield BaseNode(self,n)
SyntaxError: invalid syntax
Thanks!
This script file is just an "intermediate" solution and not really needed. I'll remove it in the next version.
i'll second that! a user-friendly guide, or even a wikipage of code snippets, would be very handy. i keep my own list but it's getting very disorganized.
lost in the wilderness
Poser 13, Poser11, Win7Pro 64, now with 24GB ram
ooh! i guess i can add my new render(only) machine! Win11, I7, RTX 3060 12GB
Quote - ODF - unfortunately, every hairstyle I've tried (at least 6, from several different sources) gives me the same 'NoneType' error. I tried loading a hair set by itself, in case being parented to a figure was causing it, but that didn't work. I tried growing a hairball, and that exported fine. I'm not sure what's going on.
I think I've found the problem. In the file pydough/from_poser.py, change line 198 from
if g.Name() ==
name:
to
if g.HairProp().InternalName() == name:
As usual, make sure not to change the number of space at the beginning of the line, since Python is very sensitive about that.
I'm not completely sure yet I understand how Poser handles dynamic hair, but this works with the Izetta hair and looks kind of logical to me.
Updated without changing the version number, because there is nothing new in this version except that I removed an included file that creates an error in P6.
Re-download if you want to give P6 a try. Please report further errors generated by P6 because I want to have P6 support as soon as possible.
Quote - i'll second that! a user-friendly guide, or even a wikipage of code snippets, would be very handy. i keep my own list but it's getting very disorganized.
I'll third it, we already have a wiki page ready, the code snippets should be commented to explain what each part does in simple terms though, it's no good just adding the code without explaining what it does & why it does it.
Windows 7 64Bit
Poser Pro 2010 SR1
HI poser 6 OSX
latest version of the exporter
getting this error now:
File "", line 82, in ?
File "Macintosh HD:Applications:Poser 6:Runtime:Python:poserScripts:LUXPOSE ALPHA:PoserLuxExporter_alpha_1#871987:workers:Parameters.py", line 113, in read
raise RuntimeError, "configfile not found: %s" % file
RuntimeError: configfile not found: Macintosh HD:Users:EMPERORTAIN:Desktop:AIR/LuxPose/data/dataOut.bbml
Not sure why it seems to be looking for "dataout.bbml file" on my desktop.
Cheers
Quote - (Sorry, a little late, replying to the person looking to make light-emitting textures some pages ago.)...
Note that each light emitting polygon is considered a separate light for Lux's raytracing calculations, so apply Light materials only to simple geometry, lest your render takes ages.
This was I, and I thank you VERY Much! :)
Lots of experimenting to do here :)
The Poser 6 PC version gets the same error as the mac version.
File "D:Poser 6RuntimePythonposerScriptsworkersParameters.py", line 113, in read
RuntimeError: configfile not found: D:Poser 6AIRLuxPosedatadataOut.bbm
Quote - The Poser 6 PC version gets the same error as the mac version.
We come closer :)
This error is because P6 doesn't find the folder this script is running from. I've replaced the old function from BB with a function from Dizzi now that works with P6.
If you like to test again, pleae re-download ...
Quote - > Quote - i'll second that! a user-friendly guide, or even a wikipage of code snippets, would be very handy. i keep my own list but it's getting very disorganized.
Yes, for me adding something about materials to the wiki is a good idea!
HI just got the same error on P6 is there a new build to download??
Cheers
"Traceback (most recent call last):
File "", line 81, in ?
File "Macintosh HD:Applications:Poser 6:Runtime:Python:poserScripts:PoserLuxExporter_alpha_1#871987:workers:Parameters.py", line 113, in read
RuntimeError: configfile not found: Macintosh HD:Applications:Poser 6:Runtime:Python:poserScripts:PoserLuxExporter_alpha_1#871987:AIR/LuxPose/data/dataOut.bbml
Quote - > Quote - > Quote - i'll second that! a user-friendly guide, or even a wikipage of code snippets, would be very handy. i keep my own list but it's getting very disorganized.
Added 4 new sections ...
** Editing your .LXM, LXS Files
****Material Code Line Explanations
**Material Code Line "Hacks"
Lights, Groups and SUN
WHAT happened to the wiki page? It looks like shit now. I reset it to the older version. sigh
I don't mind someone wanting to add something, but I think one person taking care of the wiki page in this case is enough since it can get really f'd up really fast. If we have 500 ppl adding willy nilly it will be unreadable.
Since I've been taking care (mostly) of the wiki page up to this point, please sitemail me what you want added and I'll add it. Thanks ;o).
Quote - I get this error in the p6 pc version, now:
File "", line 202, in ?
File "", line 178
return (xfm(x) for x in items)
I assume this one is because Python 2.2 can't deal only with arrays for something like this. I replaced it with return tuple([xfm(x) for x in items]) and hope it works.
Please re-download for another P6 test ...
@adp: please look on the peanut gallery. I got it running under P6 and uploaded the modified files.
All the problems I found looked Python-related, not Poser, so it might be good to try and test things under Python2.2 independently of Poser as much as possible.
Hi Still no Go On P6 OSX:
RuntimeError: configfile not found: Macintosh HD:Applications:Poser 6:Runtime:Python:poserScripts:PoserLuxExporter_alpha_1#871987:AIR/LuxPose/data/dataOut.bbml"
Cheers
Quote - > Quote -
RuntimeError: configfile not found: Macintosh HD:Applications:Poser 6:Runtime:Python:poserScripts:PoserLuxExporter_alpha_1#871987:AIR/LuxPose/data/dataOut.bbml"Cheers
For me this path looks ok - or I'm blind???
Do you have folder "AIR/LuxPose/data" and the Air config files installed?
Quote - > Quote - I don't mind the editing so much, but PREVIEW it before you make a permanent change ;o). If it looks messed up in preview, it will look messed up when you change it permanently.
Maybe it's better to have a separate wiki for material handling?
I added the sections specified by Synpainter in his forum post. So far, no one has either sent me any copy that I can add or has added anything themselves. But the sections are definitely there ;o).
I apologize if I hurt your feelings Synpainter. I just woke up to a jumbled wiki page mess and my pissy component kicked in ;o). You may now edit to your heart's content. All I ask is that you preview what you've done before you make it live to avoid any further messes. And if you need syntax help, just examine a section that's already been done to see how the wiki likes the code to be.
To make a new section, set it up like this:
==Name Of Your Section==
...then add what copy you want beneath it. That adds a new section and also adds that section to the contents block.
Quote - I see - it's a Mac problem with path-seperator!
Updated again :)
Hi here where we are P6 OSX:
File "", line 79, in ?
AttributeError: 'module' object has no attribute 'sep'**
Thanks
Ok, the classic way ...
I think we are close - would be nice if you could try again!
Hi here is the new error:
File "Macintosh HD:Applications:Poser 6:Runtime:Python:poserScripts:PoserLuxExporter_alpha_1#871987:workers:PoserLuxExporter_workers.py", line 3, in ?
reportcomments = True # comments written to outputfiles
NameError: name 'True' is not defined
Going to Lunch now will back be online after 1:30 pm New York Time
Cheers
Quote - > Quote - > Quote - I don't mind the editing so much, but PREVIEW it before you make a permanent change ;o). If it looks messed up in preview, it will look messed up when you change it permanently.
I won't have the time to do anything worthwhile for the wiki until tomorrow, when I get time I'll have a look at what's been done then try adding something, I'd rather not mess it up by rushing it, you're too scary for me to get on the wrong side of you. :b_tonguewink:
Windows 7 64Bit
Poser Pro 2010 SR1
Quote - > Quote - > Quote - > Quote - I don't mind the editing so much, but PREVIEW it before you make a permanent change ;o). If it looks messed up in preview, it will look messed up when you change it permanently.
I'm harmless...lol. Just make sure you preview before making it permanent. Otherwise I'll cut you off at the knees...lmao.
I am JUST KIDDING!! LOL But I am a little pissy for my own good sometimes, I freely admit it ;o).
@ Laurie
My skin is pretty thick so, No hurt feelings... It's all good.
People get pissy, so be it, we all have our moments...
Still stumped with trying to paste a code line in Wiki.....
For instance:
# start light "Sun & Sky"
AttributeBegin
* LightGroup "Sun"*
* LightSource "sunsky"*
* "vector sundir" [-0.6 0.5 0.7]*
* "integer nsamples" [3]*
* "float gain" [0.020]*
* "float turbidity" [3]*
AttributeEnd
# end light "Sun & Sky"
All becomes one continuous line, I "Think" the punctuation is seen as a format code of sorts by wiki.
Not sure... someone confirm?
Quote - @ Laurie
For instance:
AttributeBegin
* LightGroup "Sun"*
AttributeEnd
It very well might...let me give it a shot... I'll let you know what I find out and you can do the edits then :o).
Ok Synpainter...I think there's a sort of workaround....
I added your copy and code above to the wiki. I made it permanent so that you can see what I did and make any further additions using it as a guidline. After you make your changes, feel free to delete what I added when you no longer need it.
What I did puts everything in a box, but at least everything in the box looks like it should.
If there's anything you aren't sure of or if you can't quite tell what I did to make it look that way or if you feel uncomfortable adding it yourself, sitemail me with questions or copy to add. I'm always hanging around ;o).
Here are two more interesting Links about Lux textures/materials:
http://www.luxrender.net/wiki/index.php?title=LuxRender_Textures
http://www.luxrender.net/wiki/index.php?title=LuxRender_Materials
This line was just too high ... moved it downwards
Hi latest error poser6 OSX
File "", line 210, in ?
Exception: Make sure all files from the package are installed into the same directory.
cannot import name radians"**
Cheers
Thanks for creating the subsections for material hacks LaurieA! I'll see about posting some of the ones I've made into that section. Hopefully, they'll be more readable than the one(s) I've posted here. Also, is there a way to add images to the wiki so they don't mess up the formatting of the page?
And Wolf, I like the logo and can totally see it working for the exporter app. ^_^
Ack, forgot to mention that the hack was originally made for Miki2, but you should be able to copy and paste it for V4 with no problems.
Hope all of that helps and makes sense. ^_^
