Sat, Jan 25, 5:05 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 25 4:22 pm)
Subject: Morph Targets, Magents, and Scalling, Oh My!
Thorgrim ( ) posted Mon, 06 August 2001 at 1:35 PM ยท edited Sun, 04 August 2024 at 2:22 AM
Hi Guys, I've created a morph for Michaels cowboy boots to change them to a fantasy boot with a cuff. I've also just finished making this conform to massive mike. I made the boot fit Massive Mike by using scaling and magnets and created a morph target using spawn morph target. I then saved this modified boot to my library. But, when I recall it from the library and reconform it again I seem to loose all scaling that I had setup in the boot. Is there away to do this so I dont loose the scaling I set up? BTW: There is a bug in the CR2 for Mikes left cowboy boot. The foot is attached to the body instead of the shin, as it should be. This caused me all kinds of weird problems until I found it. It can easily be corrected by editing the CR2 in a text editor though. Also I would be glad to send the CR2 to someone by email if they want to put it in free stuff.
the3dwizard ( ) posted Mon, 06 August 2001 at 5:04 PM
Before you save the boot in the library lock the figure. This should keep all your scaleing information.
bloodsong ( ) posted Tue, 07 August 2001 at 5:30 AM
heyas; when you tell a figure to 'conform' it loses it's scaling info. i think you can save this if you memorize the figure before you save it to the library. there was a discussion about this, see the thread about.... someone was trying to re-scale and conform clothing for the p4nf dwarf figure.
Thorgrim ( ) posted Tue, 07 August 2001 at 10:14 PM
Incredible, thanks a lot. It works great.
