Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Attached Link: http://www.svdlinden.nl/webposerstuff/downloads/MorphFromObjP6.zip
There is a possibility that the current figure does not have an actor with an InternalName that's identical to a spawned prop name. This will happen when you create new groups in ZBrush.I've updated the script with error handling in the case of non-matching names - the mismatch will be reported, but the script will continue.
Thanks, svdl.
I'm now not getting any errors, but on the other hand I'm not getting any results either. After running the script (with 'Body' selected), there is a dial set to 1.000 on the Body actor when I open up the new character. There are no dials on the other actors.
When I twiddle this dial, it is completely unresponsive. Also, nothing happens when I apply the INJ pose, i.e. there is still the single dial for the main 'Body' only, which is still unresponsive when I twiddle it.
FWIW, here is a dump of the log when I ran the script :
Importing C:Vic2.OBJ
The file was not found. Do you want to continue looking for missing files? Spawning props
Turning off IK for Figure 1
Setting Figure 1 to zero morph/pose
Actor 'SkinHip' does not exist in figure 'Figure 1'
Actor 'SkinTorso' does not exist in figure 'Figure 1'
Actor 'PubicHair' does not exist in figure 'Figure 1'
Actor 'SkinNeck' does not exist in figure 'Figure 1'
Actor 'SkinHead' does not exist in figure 'Figure 1'
Actor 'SkinScalp' does not exist in figure 'Figure 1'
Actor 'Lips' does not exist in figure 'Figure 1'
Actor 'EyeSocket' does not exist in figure 'Figure 1'
Actor 'InnerMouth' does not exist in figure 'Figure 1'
Actor 'Nostrils' does not exist in figure 'Figure 1'
Actor 'Lacrimal' does not exist in figure 'Figure 1'
Actor 'Eyelashes' does not exist in figure 'Figure 1'
Actor 'Eyebrows' does not exist in figure 'Figure 1'
Actor 'Teeth' does not exist in figure 'Figure 1'
Actor 'Gums' does not exist in figure 'Figure 1'
Actor 'Tongue' does not exist in figure 'Figure 1'
Actor 'LCornea' does not exist in figure 'Figure 1'
Actor 'LEyewhite' does not exist in figure 'Figure 1'
Actor 'LPupil' does not exist in figure 'Figure 1'
Actor 'LIris' does not exist in figure 'Figure 1'
Actor 'RCornea' does not exist in figure 'Figure 1'
Actor 'REyewhite' does not exist in figure 'Figure 1'
Actor 'RPupil' does not exist in figure 'Figure 1'
Actor 'RIris' does not exist in figure 'Figure 1'
Actor 'Nipples' does not exist in figure 'Figure 1'
Actor 'SkinForearm' does not exist in figure 'Figure 1'
Actor 'SkinArm' does not exist in figure 'Figure 1'
Actor 'SkinHand' does not exist in figure 'Figure 1'
Actor 'Fingernails' does not exist in figure 'Figure 1'
Actor 'SkinLeg' does not exist in figure 'Figure 1'
Actor 'SkinFeet' does not exist in figure 'Figure 1'
Actor 'Toenails' does not exist in figure 'Figure 1'
Creating Full Body morph
Restoring IK for Figure 1
Done
Saving figure Sofi2 to library
Saving INJ Sofi2 to library
Writing INJ for actor Hip
Writing INJ for actor Abdomen
Writing INJ for actor Chest
Writing INJ for actor Neck
Writing INJ for actor Head
Writing INJ for actor Left Eye
Writing INJ for actor Right Eye
Writing INJ for actor Right Collar
Writing INJ for actor Right Shoulder
Writing INJ for actor Right Forearm
Writing INJ for actor Right Hand
Writing INJ for actor Right Thumb 1
Writing INJ for actor Right Thumb 2
Writing INJ for actor Right Thumb 3
Writing INJ for actor Right Index 1
Writing INJ for actor Right Index 2
Writing INJ for actor Right Index 3
Writing INJ for actor Right Mid 1
Writing INJ for actor Right Mid 2
Writing INJ for actor Right Mid 3
Writing INJ for actor Right Ring 1
Writing INJ for actor Right Ring 2
Writing INJ for actor Right Ring 3
Writing INJ for actor Right Pinky 1
Writing INJ for actor Right Pinky 2
Writing INJ for actor Right Pinky 3
Writing INJ for actor Left Collar
Writing INJ for actor Left Shoulder
Writing INJ for actor Left Forearm
Writing INJ for actor Left Hand
Writing INJ for actor Left Thumb 1
Writing INJ for actor Left Thumb 2
Writing INJ for actor Left Thumb 3
Writing INJ for actor Left Index 1
Writing INJ for actor Left Index 2
Writing INJ for actor Left Index 3
Writing INJ for actor Left Mid 1
Writing INJ for actor Left Mid 2
Writing INJ for actor Left Mid 3
Writing INJ for actor Left Ring 1
Writing INJ for actor Left Ring 2
Writing INJ for actor Left Ring 3
Writing INJ for actor Left Pinky 1
Writing INJ for actor Left Pinky 2
Writing INJ for actor Left Pinky 3
Writing INJ for actor Right Buttock
Writing INJ for actor Right Thigh
Writing INJ for actor Right Shin
Writing INJ for actor Right Foot
Writing INJ for actor Right Toe
Writing INJ for actor Left Buttock
Writing INJ for actor Left Thigh
Writing INJ for actor Left Shin
Writing INJ for actor Left Foot
Writing INJ for actor Left Toe
Saving REM Sofi2 to library
Done
regards,
Andrew
That looks like the correct export options.
On the other hand, if you're going to create your morphs from the figure in zero pose, it's easier to work on a copy of the .OBJ file in Runtime:Geometries (that's what I usually do).
Then it must be something in the ZBrush import or export. I don't have ZBrush, so I can't help you there.
Quote - I don't have ZBrush, so I can't help you there.
Ditto.
There have been several tutorials and threads recently about making Poser morphs in Zbrush, so one of those may help.
One thing that may work is to save the original grouping and UVs using UVMapper (either version) and then using the saved UVS file to restore the correct grouping to your morphed OBJ.
I got the same results as mathman above. It creates a new figure called the morph name, creates a new dial INJChannels->Community area, and creates a INJ in the pose area....
But none of that does anything.
Here are the settings I used, what about the no object selected at the bottom? Is that right?
Not sure what the morph channel or the morph precision are getting me there...?
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2709542
Hi all,I've imported Vic3's obj file into zBrush, made a few changes and exported the result. I then opened up Vic3's character(figure) into Poser, and ran this script (its referenced in the attached link). It ran OK for part of the way and then crashed with a traceback.
Here is the log that the python script spits out :
Importing C:Vic3.OBJ
Spawning props
Traceback (most recent call last):
File "C:Program Filese frontierPoser 7RuntimePythonposerScriptssvdlMorphFromOBJP6.py", line 657, in ?
SpawnFBM(fig,morphChannel,morphName,plist,useFBM)
File "C:Program Filese frontierPoser 7RuntimePythonposerScriptssvdlMorphFromOBJP6.py", line 412, in SpawnFBM
act=fig.ActorByInternalName(actName)
poser.error: Figure has no actor by that name
Note : the error in line 2 "The file was not found. Do you want to continue looking for missing files?" is in reference to a bmp that it is looking for, and I cancel out of.
Any help appreciated.
thanks,
Andrew
