Mon, Dec 23, 12:43 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Dec 02 3:16 pm)
Subject: Is This a bug SetShadowBlurRadius or ???
grichter ( ) posted Fri, 24 September 2010 at 10:05 AM · edited Mon, 23 December 2024 at 12:31 AM
PP2010 all updates Mac version
PP2010 Manual says
Raytrace Shadows: Selecting Raytrace Shadows enables raytracing of shadows. Traditionally, raytracing results in clear, hard-edged shadows. However, Poser offers a method for softening the shadow edges, thus adding more realism to your raytraced shadows. You can control this effect using the Shadow Blur Radius dial (see below).
then the manual says (All bolded by me)
Shadow Blur Radius: All shadows have a blurry region around their edges. The Shadow Blur Radius parameter specifies the radius of this blurry region. By default, this dial is set to a low value. Raising the blur radius increases the soft shadow edge effect.
If the shadow is set to raytaced and I try this via a python script nothing changes. The value stays as is.
light.SetShadowBlurRadius(3.0)
If the shadow is set to DepthMapped then light.SetShadowBlurRadius(3.0) works.
Or if I run the script with the above code in raytrace mode I see no change as stated above. Change the shadow to depthmapped and the change appears by changing the shadow type or changes to 3.0, then change the shadow type back to raytraced and it holds at 3.0.
1.) Either I am doing something wrong
or
2.) it's a bug.
Anybody got as clue as to what's going on?
Thanks
Gary
Gary
bagginsbill ( ) posted Fri, 24 September 2010 at 1:34 PM
Bug.
grichter ( ) posted Fri, 24 September 2010 at 9:07 PM · edited Fri, 24 September 2010 at 9:18 PM
Thanks BB
Reported to SM
Gary
semidieu ( ) posted Sat, 25 September 2010 at 4:06 AM
If I recall correctly, I already mentioned this at SM (saw this already since Poser 7)
grichter ( ) posted Sat, 25 September 2010 at 7:48 AM
Did a search in the bug tracker for SetShadowBlurRadius so I could tack on to prior reports and saw nothing. Either way, lets hope they fix it :)
Guess I could change the shadow type in my script to Depthmapped then back to raytraced as a work around :)
Gary
semidieu ( ) posted Sat, 25 September 2010 at 8:16 AM
This was before they made the thread public to all beta tester. So it's certainly still in 'private' state.
grichter ( ) posted Mon, 27 September 2010 at 10:24 AM
A reply came back from a reporter to my bug report that states:
"For softness of raytraced shadows, you have to use the (Set)ShadowRaytraceSoftness methods. They are new in version 8.0.3.11575. In earlier versions, you can't change blurring for raytraced shadows from Poser Python."
Gary
semidieu ( ) posted Mon, 27 September 2010 at 1:55 PM
I saw this... And tried it in Poser Pro 2010... And this was not working... but now I know why. The build version of Poser Pro 2010 is still older.
grichter ( ) posted Mon, 27 September 2010 at 4:44 PM
Quote - I saw this... And tried it in Poser Pro 2010... And this was not working... but now I know why. The build version of Poser Pro 2010 is still older.
makes sense because the debug reporter asks if you have 10.4 and the public build is 10.3, which is what I have. So one more update it appears.
Gary
