Sun, Feb 2, 7:27 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 7:25 pm)
Subject: Need help - Trouble saving in Poser Pro 2010
3DNeo ( ) posted Thu, 30 September 2010 at 1:05 PM · edited Sun, 02 February 2025 at 7:23 PM
I am having trouble saving files to my Poser Pro 2010 library. For example, I create a custom Pose and want to save it in my "Pose" folder. When I do, I get the error message shown here in the photo. Not sure what the problem is because I can save and load a PZ3 just fine, it's just when I try to save to my library it is doing this. My Poser Pro 2010 is running on Windows 7 64 bit, 10GB RAM and I have set the program to run as "Administrator" so it should be saving it OK I would think. Also, I am running the Poser Pro 2010 SR1.1 update so it is the most current version.
Any thoughts on this appreciated, not sure what is causing it.
Jeff
Development on: Mac Pro 2008, Duel-Boot OS - Snow Leopard 10.6.6 & Windows 7 Ultimate 64bit, 2 x 2.8 GHz Quad-Core Intel Xeon , 10GB 800 MHz DDR2 RAM, NVIDIA GeForce 8800GT.
bagginsbill ( ) posted Thu, 30 September 2010 at 1:19 PM
I'm guessing.
You have UAC turned on.
The folder JSHStudio was created in the virtual store, not really in Program files.
Meanwhile, you're running Poser as administrator, so it is trying to put something in the REAL location, but it doesn't really exist.
3DNeo ( ) posted Thu, 30 September 2010 at 11:05 PM
Quote - I'm guessing.
I checked to verify and I did in fact create the directory in Program Files and it does exist there. It is located in the main Windows 7 Program Files directory, NOT the x86 directory. Could that be the problem, it is looking for it in the 32 bit directory? I am running the 64 bit version of Poser Pro 2010 though so I don't know why it would be looking in the x86 directory for it.
Thanks.
Jeff
bagginsbill ( ) posted Thu, 30 September 2010 at 11:22 PM
I doubt it's looking in the other directory.
Truthfully, I never looked at how the 32 and 64 bit versions are installed together until just now. It looks like each gets its own runtime. That seems like an odd choice.
3DNeo ( ) posted Fri, 01 October 2010 at 12:49 AM · edited Fri, 01 October 2010 at 12:51 AM
Quote - I doubt it's looking in the other directory.
I know what you mean, but I think that is because it is like other programs such as Adobe Photoshop where it has two totally different installs. One of them is in the Windows 7 64 bit Program Files directory and the other in the 32bit x86 directory. Each of them running independently.
Also, another thing that is odd is I don't see any uninstaller in my Control Panel program list for Poser Pro 2010 or Poser Pro 2010 32 bit version. Only a Poser Pro 2010 content uninstall. Is yours the same too?
Not sure what is causing this because it only is a problem when saving to the library. I can install new content just fine by either hand copying them to the right places or just unzipping in the Poser Pro 2010 directory. So, I may have to contact Smith Micro tech support on this and see why I can't save content there as I have no clue at this time.
Jeff
LostinSpaceman ( ) posted Fri, 01 October 2010 at 2:51 AM · edited Fri, 01 October 2010 at 3:00 AM
You never answered whether or not you have UAC turned on. I don't have any issues saving content to my runtimes because I told Poser Pro 2010 to create it's content in an external runtime outside of Program Files area because of UAC.
And yeah, it still creates a 32 and a 64 bit runtime in both Program Files and X86 directories. This is awkward when keeping your Python Scripts updated because you have to change files in  both directories if you use both 32 and 64 bit and switch back and forth as I do.
3DNeo ( ) posted Fri, 01 October 2010 at 10:20 AM
Quote - You never answered whether or not you have UAC turned on. I don't have any issues saving content to my runtimes because I told Poser Pro 2010 to create it's content in an external runtime outside of Program Files area because of UAC.
The UAC question was not addressed because that was a non issue as I did not have UAC turned on to begin with or else I would have mentioned it. Still don't know why there is no un-installer for the 32 and 64 bit Poser versions either so that is another question to ask.
Jeff
3DNeo ( ) posted Fri, 01 October 2010 at 12:42 PM
For the answer to this thread topic, the solution was to uninstall and reinstall. What was happening according to tech was a corrupted permissions issue in Windows 7 and it got messed up. It happens sometimes and the only way to really correct it is to install the program again.
Also, the answer about the uninstall is there is no separate uninstall for 32 bit, however to uninstall you have to go to your Program Files>Smith Micro>Poser Pro 2010>uninstall directory and launch from there. They know it does not show up in Control Panel for some reason so you have to find it manually.
Hope this helps others maybe.
Jeff
