Attached Link: CLICK HERE and See Pages 9-13
Hi Misty,Maybe the "crew" can help. (Click the link above the image for more info)
cheers,
dr geep
P.S. Mods ... Sorry 'bout the duplicate post ... I deleted the original by accident. ...:cursing:
cheers,
dr geep ... :o]
edited 10/5/2019
Thanks. I don't really understand it though.
depth of field is verry mysterious.
i see the tick box in my render settings (P7), just begging to be understood.
where is Naysay Guy? he's not in the crew
♥ My Gallery Albums ♥ My YT ♥ Party in the CarrarArtists Forum ♪♪♪ 10 years of Carrara forum ♥ My FreeStuff
Quote - Thanks. I don't really understand it though.
i see the tick box in my render settings (P7), just begging to be understood.where is Naysay Guy? he's not in the crew
NaySayGuy not in the crew???
Count your blessings my dear, count your blessings. :lol:
Did you view the other pages in the tut?
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
yes, thanks, waiting for it to sink into my brain.
i just bought on a fresh pot of pumpkinspice coffee.
i see an old python script for P5 depth of field, hopefully it has a kindly comments section.
Have you gone into the Display menu? Choose Display from the top, then scroll down to Guides, then choose Focus Distance Guide. This will put a large "X" in your current window with a sphere and torus in the middle.
Above your parameter dials is another dropdown menu. Click on it and choose Cameras, then Main Camera. When the dials show up for the camera, you will see a dial called "focus_Distance". Depending on what you want to focus on, turn this dial to the point where the large guide (the "X") intersects whatever is your main focal point (what you want to focus on).
Once this is complete, go to your Render settings. You should see the Auto settings. For sake of argument, let us go with what I use. Your mileage may vary ;-) Move the slider to the Final setting. Once that is done, click on Manual Settings. This will take you out of the slider area. You will see a BIG button called "Acquire from Auto". Click it. Now your settings have changed. Move Raytrace bounces to 2 if you have no transparencies. Near the bottom of the list is a setting called Pixel samples. This is where the magic happens. Set it anywhere between 15-20. This will cause your render to take forever, but it will be worth it. To the right, under Options, is a box called Depth of field. Put a check in there.
Now all you have to do is click on Render Now. Site mail me if you have still have issues with DOF.
This is an example of DOF done in CS3 using a z-depth jpeg image with a png..
http://www.renderosity.com/mod/gallery/index.php?image_id=2114391
Injustice will be avenged.
Cofiwch Dryweryn.
Is the python script NOT in newer versions of Poser? I know P6 came with a script for calculating the DoF. Poser 7 has one as well. Under the Render / IO button. Pretty sure all you have to do is select the camera you're shooting from, and then an object, and run the script.
There was a long thread on this subject some time ago. Stewer, I believe, wrote the python script.
Best Wishes,
Rªnce
Quote - This is an example of DOF done in CS3 using a z-depth jpeg image with a png..
nice example. but how did you do it?
Airport security is a burden we must all shoulder. Do your part, and please grope yourself in advance.
You need to make 2 images, the colour png one and the z-depth one which is essentially a grayscale image, similar to an alpha channel that is a graphical representation of depth. With a z-map every pixel in a scene is assigned a 0-255 grayscale value based upon its distance from the camera. Usually the objects closest to the camera are white and the objects furthest from the camera are black with various shades of grey in between.
You then take both into CS3 or similar and add the z-depth image to the "channels" of your png image. You then go to lens blur and set the amount of DOF and from what point you want the focus to be.
There's a bit more to it than that, if there's no tutes about, I'd be happy to do a step by step if anyone is interested.
Any tute I might do would be using photoshop though because that's what I use.
All my DOF images are done in this way, I just posted a new one with the DOF exagerrated to show how much control you have over it using this method.
http://www.renderosity.com/mod/gallery/index.php?image_id=2116396§ion_id=&genre_id=&np
Cofiwch Dryweryn.
this is a DOF render straight out of Poser.
There is something wrong.
Now I know why people are saying Poser DOF is no good.
(it is NOT the weird look of the edge of the table top that is wrong - that's my fault with the pixel samples) .
what's wrong is - look at the tile grout.
something tells me ....if you had a camera lense with a shallow DOF , the tile grout would not look expanded like that ...it would actually almost disappear.
______________________
"When you have to shoot ...
SHOOT.
Don't talk "
- Tuco
Santicor's Gallery:
http://www.renderosity.com/homepage.php?page=3&userid=580115
Here is a rendered DoF.
http://www.renderosity.com/mod/gallery/index.php?image_id=1982426&user_id=343328&np&np
you select the object you want to be in focus, run the script.
then copy the value to the 'focal distance field'
in this image, i set the f-stop to 3 and pixels to 5.
I'm not sure which version of poser came with the script. I ported my runtime forward, it could've came with P6 or p7.
The first copy of the script came with Poser 5, written by Stefan Werner, aka Stewer. The script has been carried forward through Poser 6 AND 7 (not sure about newer versions of the software). It's actually NOT at all hard to use, second MistyLaraPrincess ' above. Just remember when rendering to check the 'Depth of Field' in the Render Settings window.
Here's an ealier thread about the subject:
http://market.renderosity.com/mod/forumpro/showthread.php?thread_id=2014883
bushi created a nice image to use as a guide/setup tool - located on page 4 of the thread. I think we were playing with Poser 6*, not sure, but it works the same way in Poser 7.
Best Wishes,
Rªnce
EDIT: It was Poser 5 the folks in the thread were playing with. Those were the days ...
it takes luck to use the depth of field feature.
no matter how many setting tries, i can't make the character be in focus, the whole scene is fuzzy or fuzzier.
if i leave the character in the default xyz and the backgrop is z-5.00
what settings do you use to make the character in focus?
Thanks!
