Sun, Jan 19, 11:35 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 19 10:45 am)
Subject: Poser 8 and casting shadows from lights
ariasparkle ( ) posted Thu, 07 October 2010 at 10:03 AM · edited Sun, 19 January 2025 at 9:18 AM
 Hi all quick question . I am using vex lights and other lights, I use vex most of the time, I  would like them to only cast shadows on my figure, but not on the ground, Is there a way to get rid of this ground shadow in Poser 8? Basically make the ground invisible? Or change the settings to make this shadow go away? I have been playing with the dials and can't get them to go way. I do want the shadows to cast on the figure to give her more depth and realism. Thank YOU!!
never mind vigured it out. Just turn the ground off and turn of the ground shadows. :)))
ratscloset ( ) posted Fri, 08 October 2010 at 12:15 AM
You can make the Ground invisible.  (Select the ground and go to the properties and uncheck visible, visible in Raytrace, etc... )
ratscloset
aka John
ariasparkle ( ) posted Fri, 08 October 2010 at 10:32 AM
 Thansk I figured it out right after i sent the message. lolol
Callie
