Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 20 6:12 am)
You must have searched only in the last 45 days as there are literally hundreds of posts about this.
You want to use a free tool to convert RSR files to PNG
Quote - Unless you have the full version of P3dO which allows you to select runtimes for rsr to png conversion.
In any case, I think Poser itself should do the conversion automatically when reading folders. I might be wrong but I think P5 or P6 did that.
Poser 6 read both formats I believe. Poser 8 does not.
Quote - Indeed P5 and P6 work properly, not P8. That's an upgrade.
Here is Dizzi's converter: http://www.renderosity.com/mod/freestuff/details.php?item_id=57197
I shall try it today. Thx everyone.
It didn't really matter that Poser 8 was an upgrade or not. Poser 8, upgrade or full version, doesn't have the capability to still read .rsr files like previous versions do. I guess SM figured it was no longer necessary since Poser has been using .png rather than .rsr since version 5 or 6. There are at least two free programs that I know of that will convert older .rsr previews - Dizzi's freebie and P3d0. Either will do the job :o).
Quote - P6 is the only version which can do this feature. But that would mean loading all your content into P6, and, IIRC, still have looming .rsr's present in your folders. That could add up to additional, valuable HD real estate wasted due to extra image overhead.
The OP said he moved from P6 to P8. Unless he reinstalled all his old content into P8 it should have been fine.
A .rsr take about 5K of space. Really, even 10,000 of them only add 50 Mb, rather insignificant amount for contemporary disk drives of 100 GB or more.
The story was a little bit longer: PC crashed and that was terminal, rest his silicone soul. New PC, mighty beast and last of my nickles to finally going P8. So fresh start. Weeks of reinstallement etc.
By the way Dizzi rules! All clean nice and sharp thumbs in no time.
Problem solved. Happiness at last!
Thanks guys for the support.
S
Hi everyone,
I've just moved from P6 to P8 and all the oldest thumbs don't appear in the runtime menus. No png no thumb so it appears. With the bew stuff no probs but with the ones without pics I only get the default 'no pics' and the anme of the stuff. No easy way for MAT pose
Can't find a thread about this so I suppose I'm to dumb to find the evident solution...
Can anyone point me in the right direction?
Thanks
Stephane
