edit the abbreyiated col references to column in a text editor the newer python ver doesn't recognize "col"
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
Not the pyc file, the py file. Pyc is the compiled binary.
Here is a copy of the error message that I am getting:
Traceback (most recent call last):
File "C:Program Files (x86)Smith MicroPoser 8RuntimePythonposerScriptsScriptsMenuRealism KitsV4SkinRealismKit.py", line 18, in ?
import V4SkinRealismKitToolsP7
File "RuntimePythonposerScriptsV4SkinRealismKitV4SkinRealismKitToolsP7.py", line 22, in ?
ImportError: No module named pzrXml10_24
So set up your scene in Poser 8 you like then open in Poser 7 to run Realism Kit and save now it's a textured figure and you can render in 8 since the change between ver 7 and 8 (that we're dealing with here) is in the python version
Charles Péguy
Quote - Traceback (most recent call last):
The key things in that error message are that we're talking about the "V4 Skin Realism Kit" sold at DAZ, and that you most likely are either trying to run it from the wrong Runtime, or copied only some of the files to your P8 Runtime, rather than reinstalling (the "pzrXml10_24" module is one for making Poser's XML dialog descripitions easier to use). So the best thing to try is reinstalling in your P8 Runtime.
Unfortunately, links to his faq & problems forum are apparently down and no alternates are available. I would recommend direct contact with FaceOff for your solution. Email below:
If there is an update, you should be able to reset the download and get the newer version...
"Oh - the manual says that? I have never read the manual - this must be why."This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hello,
I have been using the Unimesh Realism Kit by faceoff for quite some time and now that I have upgraded from Poser 7 to Poser 8 it no longer works. Is anyone aware of where an updated verion of this script may be found? Or can someone suggest a suitable replacement? The simpler the better as I am not that knowledgeable when it comes to shader nodes.
Thanks for any replies.
nabob21
